Results 1 to 14 of 14
Thread: vp alternator light comes on intermitently
    azz
    azz is offline azz
    vp wagon
    May 2008
    maryborough
    Question vp alternator light comes on intermitently
    hi all, on my vp wagon the alternator light is coming on for about ten seconds every now and then, ie not just after starting and not just after using lights etc. it is charging properly the battery is basicly new and it is not drawing current back through system at rest, i dont get it. thanks
    V8 WK Caprice + VK berlina
    Mar 2008
    Blakeview, Adelaide
    Have you checked all the obvious things like the brushes on the alternator and all the connections?
    azz
    azz is offline azz
    vp wagon
    May 2008
    maryborough
    havent checked brushes but connections all look good earth is good and rubber boot around the power cable to the alternater isnt touching anything
    VP Executive R-spec
    Jan 2005
    It's most likely the brushes, the plate at the back of the alternator comes off and you buy a new one (about 60bucks?) the alternator itself lasts about 3 sets
    Morton's Avatar
    Fairstar the Funship
    May 2006
    Yeah, what they said. Get another alternator.
    I had the same issue, got myself a $20 alternator from the wreckers, and it never happened again.
    The 1972 HQ Kingswood
    Mar 2008
    Blakeview, Adelaide
    I had a datsun 120Y (don't laugh) and I just bought the brushes on their own instead of the whole cartridge and soldered them in myself. Cost me $6.50
    VN Series 2, FG R6 Ute
    Aug 2007
    S/E Suburbs
    Hey my VN does the same thing, Mine isn't the altenator though. My Voltage regulator needs to be replaced. It was damaged/moved when the themostat was replaced. Hope this helps.
    VrWagz1's Avatar
    Vr S2 exec 5.0 man Wagon
    May 2008
    wollongong
    Happened to me to. It was most likely the brushes worn out, i just went and got an exchange alternator and wacked it it to save time and effort. Was the easiest, but probably the most expensive way out of it. Ring around for a few prices though, i found they varied alot between a few stores
    vs commodore V6 S2
    Nov 2006
    maryborough QLD
    mine did the same ..was the regulator . however i replaced to whole alternator with one i had on my wreck as it was like new (alternator and regulator....not bad for a whole 150 bucks i spend on a complete vn :P)
    VRII Acclaim
    Jul 2005
    It could also be a bad connection onto the battery or even a bad battery. How do you know it is charging properly? Have you used a multimeter to check the voltages? As guys above have said, most likely the alternator but not always.
    VN Wagon
    Feb 2005
    I had this happen to me last year. In the end it was the regulator. Easy to change and it cost me about $55.
    azz
    azz is offline azz
    vp wagon
    May 2008
    maryborough
    vn executives
    Sep 2005
    Quote Originally Posted by azz View Post
    thank heaps i think i will check the brushes and go from there
    hi, guys, where is the brush, inside the alternator?
    VN Wagon
    Feb 2005
    It was the regulator as well on our car.
  1. Battery Light On, Alternator or something else?
    By phaze204 in forum VR - VS Holden Commodore (1993 - 1997)
    Last Post: 10-04-2008, 09:28 AM
  2. Alternator Warning Light & ABS OFF Light
    By Harvs82 in forum VR - VS Holden Commodore (1993 - 1997)
    Last Post: 12-01-2007, 10:10 PM
  3. VX Alternator Light Always on.
    By Raggyman in forum Electrical Wiring / Questions
    Last Post: 25-10-2005, 07:34 PM
  4. alternator light comes on then goes off intermitently
    By lowrida56 in forum VN - VP Holden Commodore (1988 - 1993)
    Last Post: 02-09-2005, 06:24 PM
  5. flickering alternator light
    By Tony2 in forum Electrical Wiring / Questions
    Last Post: 22-04-2005, 08:46 PM
