Results 1 to 4 of 4
Thread: engine oil leak
    Vn Calais
    Apr 2007
    Default engine oil leak
    my s1 calais leaks engine oil when on a steep hill facing upwards, doesnt leak from engine operation at all, thinkin either sump or rear main but seeing as its only when parked on steep hill most likely sump gasket. any ideas?
    p.s. kinda crippled with a broken leg atm so cant get under and check it
    PaRaDoX's Avatar
    PaRaDoX is offline boosted!
    Forester GT, VT S Supercharged, Supra Turbo
    Apr 2005
    Melbourne, Victoria
    its most likely your sump gasket mate, you sure its oil engine or not trans?
    i reccomend getting a mate to jump under and give all the sump bolts you can get to a tighten, they will be loose! i bet thats your leak mate!
    this is a very common problem due to the gasket expansion, the bolts get untorqued over the years, i had a leak from my v8 rear, got under and tightened all the sump bolts and bingo not a single leak
    but it could also be the trans extesion housing seal (where tail shaft connects) they go commonly aswell, and the oil might be collecting dirt on its way down and looking engine oil colour.. its something to consider
    my advice is get a mate whose not broken :P supply beer, and clean the whole under neath, drive it for a bit (ie make it leak) then identify the leak, but it cant hurt to tighten the sump bolts
    Vn Calais
    Apr 2007
    yeah thanks for that, its only happened 2x and first time i thought it was trans then wen it happened the other day(parents live on very steep gravel driveway)i put my finger in it and smelt it and its definently engine oil.
    vs commodore V6 S2
    Nov 2006
    maryborough QLD
    i had a massive oil leak that was thought to be rear main (previous owner said rear main ) lol but yeh rear main is fine was sump gasket....every time on a big hill was dripping HOWEVER could also be rear main...cant really tell unless visually inspected
    good luck
  1. Vacuum Leak, but in the engine bay
    By xtr3 in forum VT - VX Holden Commodore (1997 - 2002)
    Last Post: 07-02-2008, 09:13 PM
  2. Engine bay fuel leak
    By s_pack in forum VN - VP Holden Commodore (1988 - 1993)
    Last Post: 21-10-2007, 09:41 PM
  3. leak coolant and oil from Engine?
    By andyli in forum VN - VP Holden Commodore (1988 - 1993)
    Last Post: 17-01-2007, 05:04 PM
  4. HELP! VP Engine Fuel Leak.
    By azkwazere in forum VN - VP Holden Commodore (1988 - 1993)
    Last Post: 04-09-2005, 01:14 AM
  5. VP Engine oil leak
    By newo in forum VN - VP Holden Commodore (1988 - 1993)
    Last Post: 05-04-2005, 04:32 PM
