Results 1 to 10 of 10
Thread: please help, wtf is wrong with my level 3 speedo?
    pow3rslave's Avatar
    pow3rslave is offline DoNothing Member
    VP 5.0L
    Oct 2005
    eastern subs, vic
    Default please help, wtf is wrong with my level 3 speedo?
    ok, so driving home from my folks just now, on the last leg of the journey i noticed my speedo was going mental.
    basically taking off from the lights i look down after it catching my eye doing something odd, it would flick up to 80 in less than 1 second on takeoff, or when i put revs through it, but when i was cruising at speed it dropped down to 0, then at the next lights i'm sure the dash lights dimmed and the car idled kinda rough. i pulled over in a side street and used the digital speedo feature, only to find that similarly mental as well (on top of all this, the over speed light was going on and off as if i was actually doing the speeds it thought i was)
    also when i pulled in to the side street to digital speedo it, as i slowed to pull up the battery light flickered on a bit.
    on the plus side, my car does 0-80 in less than a second!
    pow3rslave's Avatar
    VP 5.0L
    Oct 2005
    eastern subs, vic
    ok, so today the speedos 100% dead, i did some reading and it seems it might be the sender unit, there's threads on this, but something else also happened, the fuel used gauge was also dead, but more than this the car stalled twice on the drive to the station this morning.
    i wouldn't be super ****ed about this, but the second time was when i was going round a corner in a side street, stalled as i was doing this (clutch in) and the ****ING STEERING LOCK PIN CAME ON!!! so i was stalled, freewheeling with steering stuck on hard lock.
    fortunately there was nothing there to crash into so i only mounted the curb (a bluestone one, so not as high)
    it could have been worse, but no damage done (i'll check the rims properly when i get home) and no-one hit.
    vs commodore V6 S2
    Nov 2006
    maryborough QLD
    hey mna glad you are ok
    as for the stearing lock comming on....dindt think it was supposed to unless the key is taken out...maybe casue the car stalled you lost power steering an that may have been what happened. as for the problem with the speedo etc...cant help ya there..mine a executive lol
    88GreenVN's Avatar
    88 Green VN Wagon 389,000kms
    Jun 2006
    Deep South - VN Country
    Could be ECU or speedo sender thingo that goes into the gear box. The stalling does point to the ECU with all the other dash lights and warnings going mental.
    If you have not fiddled with the dash I'd suspect the ECU first. If it was just the speedo - speed sensor.
    and 3 Dangerous non ABS VN's
    pow3rslave's Avatar
    VP 5.0L
    Oct 2005
    eastern subs, vic
    88GreenVN's Avatar
    Jun 2006
    Quote Originally Posted by pow3rslave View Post
    so i can just grab a new ecu and chuck the foam chip i got now in it?
    Yep. Get a temp ECU/Memcal and just swap the cables over - see if it stops the mental attacts
    pow3rslave's Avatar
    VP 5.0L
    Oct 2005
    eastern subs, vic
    i'll try that, but i also found some way to test the speed sensor with a test light, so that i might do that before i spend cash on it.
    i also just cracked out aldl, and i had the usual o2 errors (damn pacies) and also a speed sender error.
    pow3rslave's Avatar
    VP 5.0L
    Oct 2005
    eastern subs, vic
    ok, so i took it in to get it looked at, they did the speedo sender, and reckon the stall was from the IAC valve, which they cleaned out.
    pretty ****ed off, i got new rotors and pads up the front last week, now this. i hate having to spend money on a car i don't really want anymore. i'm going to get everything rwc-worth and sell it.
    VP Calais '93
    Mar 2006
    SA- NE BURBS
    pow3rslave's Avatar
    VP 5.0L
    Oct 2005
    eastern subs, vic
    haven't picked it up, but yeah the guy says it's working now, and that it's idling better after cleaning out the throttle body.
    i coulda gone to a wreckers and gotten a 2nd hand one for about a 10th of the price, but i'm just stupidly busy, plus no way to get there
  1. level 2 tacho into level 3 dash
    By andynogo in forum VN - VP Holden Commodore (1988 - 1993)
    Last Post: 12-07-2008, 05:34 PM
  2. VS Speedo not working (level 2), can anyone advise?
    By VS Omega in forum VR - VS Holden Commodore (1993 - 1997)
    Last Post: 19-11-2007, 06:35 PM
  3. level 3 speedo
    By PRH in forum VN - VP Holden Commodore (1988 - 1993)
    Last Post: 02-09-2007, 10:40 PM
  4. speedo reading wrong
    By burns#44 in forum VN - VP Holden Commodore (1988 - 1993)
    Last Post: 24-11-2006, 09:10 PM
  5. Level 1 dash cluster to level 3
    By SSbeast in forum VR - VS Holden Commodore (1993 - 1997)
    Last Post: 17-10-2006, 06:28 PM
