+ Reply to Thread
Results 1 to 11 of 11
Thread: Wheel Being Pushed Back.
    mischa's Avatar
    mischa is offline Mmmmm, 4 bolts.... mischa Calais
    VN V6 T5 - 355 VN GRP A REP T56
    Jun 2005
    Ashbury, NSW
    Default Wheel Being Pushed Back.
    As title say's, i dont know what's wrong with it.
    Just to wipe out thing's it could/couldnt of been, i havent hit any gutter (altho mums driven it and she is very scared to tell me if she's ever damage it) springs & shocks where replaced a while ago but didnt apear stright after i done that.
    Picture of wheel second page: My 1989 VN.
    More then wanting to know what the cause was, i would like to know how to fix it.
    cheers.
    The Daily VN T5V6
    355 VN GRP A REP
    UNKNOWN's Avatar
    UNKNOWN is offline DEFECTED UNKNOWN Executive
    95 VR SII BT1 5 Speed
    Jan 2008
    NW Adelaide
    Bent lower control arm and/or radius rod. Not too hard to replace.
    Shut up when I'm talkin' to you, you hear me, answer me!
    mischa's Avatar
    Jun 2005
    Ashbury, NSW
    I had i feeling it was that, thanks.
    The Daily VN T5V6
    355 VN GRP A REP
    UNKNOWN's Avatar
    Jan 2008
    NW Adelaide
    No problem, good luck with it. If you need any help when it comes time to doing it just let us know. Just done my Mums car a few weeks ago, bought the control arm and 'Z' bar all as 1 for $35 from a wrecker. Also had mine out of my car today changing the radius bushes.
    VP Exec
    Jun 2005
    Where are the top bearings in the strut tower? The top bearings are eccentric to the strut towers (body) and there are three possible orientations. If you didn't mark the location when you did the springs, perhaps they are not in the correct spot.
    rch-13z's Avatar
    rch-13z is offline im rick james..... bitch! rch-13z ClubSport rch-13z ClubSport
    VT Exec
    Jan 2008
    South-West Sydney
    yeah for sure thats it, brought my memory back.
    Like I said misch.... very very cheap...
    Consequences of drifting up gutters...
    PaRaDoX's Avatar
    PaRaDoX is offline boosted! PaRaDoX ClubSport PaRaDoX ClubSport
    VT S Super6, STI Liberty GT, Supra Turbo
    Apr 2005
    Melbourne, Victoria
    dosnt look out of place to me, my calais had a bent chassis which made mine sit in :P
    georgeonboost's Avatar
    georgeonboost is offline clutch it! georgeonboost Executive
    slammed VP EXEC
    Jun 2005
    Melb SE Suburbs
    Quote Originally Posted by PaRaDoX616 View Post
    are you blind gordon? that wheel is pushed back!!!
    -George
    Jun 2006
    Western Aus.
    Mine used to sit right back like that from stuffed bushes. Used to scrap on the back of the guard.
    Replaced all the bushes and went some adjustable radius rods... now drivers side scraps on the battery box at full lock... whoops, too much adjustment, but works well on the track, just needs a small tweak to get right.
    vn/vp Speedway Street Sedan
    Sep 2005
    I reckon Unknown and Cheap6 are on the money!
    Also check that the actual radius rod "Z bar" is tight at the front where it passes through the K Frame bush. The K frame can deform quite easily there too and gets pulled back in on itself if someone has had a previous heavy bump or prang. It is hard to notice at first until you compare both sides closely.
    mischa's Avatar
    Jun 2005
    Ashbury, NSW
    Well ill get some spares off the wreck i got and replace them when i got time, see if its better then.
    The Daily VN T5V6
    355 VN GRP A REP
+ Reply to Thread
  1. Red Fluid near back left wheel
    By DzRBenson in forum VR - VS Holden Commodore (1993 - 1997)
    Last Post: 11-05-2008, 02:26 PM
  2. Park lights when brake pedal is pushed
    By Greg_Sian in forum VT - VX Holden Commodore (1997 - 2002)
    Last Post: 06-07-2006, 03:55 PM
  3. bent my wheel back, help!
    By semi in forum VR - VS Holden Commodore (1993 - 1997)
    Last Post: 15-04-2006, 05:22 PM
