Results 1 to 9 of 9
Thread: lp gas can it be wired to work with a calais dash
    vn/vr Commodore wagon
    Dec 2006
    Broadmeadows Victoria
    Exclamation lp gas can it be wired to work with a calais dash
    just about to get lp gas install on my car and was wondering whether anybody out there knows whether it can be wired to work on the calais dash
    also which switch to use is there many sorts or is there one made to fit like part of the dash
    Idenity Crisis
    VN toyota lexcen/Holden Commodore
    Vr Front end, Vs interior and a calais dash
    adam69 is offline Banned
    VT Clubby
    Oct 2004
    I had a VQ on LPG and it worked from the cluster.No extra gauge for gas.Will be hard to find a switch to suit the dash so just try and find a spot where it doesnt get noticed.
    mischa's Avatar
    mischa is offline <- 245rwkw Holden V8
    VN V6 T5 - 355 VN GRP A REP T56
    Jun 2005
    Ashbury, NSW
    no idea how gas works, but making a switch out of where the aircon one is would be neat. In a wagon its got the rear wiper next to it leaving one free?
    Quote Originally Posted by keza87 View Post
    Really who wouldn't want to give Jack a good smack in the back of the head.
    The Daily VN T5V6
    355 VN GRP A REP
    Haydz's Avatar
    Haydz is offline 346 cu/in
    VS UTE LS1 T56
    Nov 2007
    Liverpool.Sydney,NSW
    just got my vr done and they have put a switch including a led gauge of gas left. in the hole where the foglight switch goes on ss models.
    VZ SS LS1
    May 2008
    North Brisbane
    my VT is dual fuel (gas and petrol) They just put an extra button next to the steering wheel in the dash, and the original fuel gauge changes depending wheher your on gas or petrol.
    VP Exec
    Jun 2005
    The existing fuel gauge can be made to work using the sender from the LPG tank, including on VN or VR Calais. The gauge will then read the tank level for whichever fuel is being used, as for adam69's VQ and coo dawg's VT.
    The trip meter uses a calculation based on injector pulse width to display the fuel consumption rate. That will still be as for petrol and therefore not accurate on LPG. (Hopefully the LPG installer will disable the petrol fuel system on LPG in such a way as to leave the injector pulse width available - there are few ways in which that can be done.)
    There are a few types of LPG switch around. The neatest, if it is the VR being converted, is probably the factory style LPG switch which goes in the dash. If it is the VN or you don't like the factory switch for the VR, easiest will be to ask your installer for examples. There is a requirement under the LPG standard (AS1425-2003) that says the switch must indicate which fuel it is that is being used, so you can't use just any switch without ensuring that is the case.
    VT Clubby
    Oct 2004
    Quote Originally Posted by Cheap6 View Post
    My trip meter on my VQ was accurate on LPG,fuel used,ltr/100klm etc.My car ran on gas for 95 percent of the 6 yrs i owned it.Dont know how it worked but it did.
    PaRaDoX's Avatar
    PaRaDoX is offline boosted!
    Forester GT, VT S Supercharged, Supra Turbo
    Apr 2005
    Melbourne, Victoria
    Dec 2006
    gas has been installed on my car today all works well apart from the ugly lpg gauge that they put in
    does anyone know how to wire the gauge to the fuel gauge on the cluster and use a normal switch to change between gas and petrol
    Idenity Crisis
  1. level 3 dash, who knows how to work it?
    By pow3rslave in forum VN - VP Holden Commodore (1988 - 1993)
    Last Post: 13-02-2008, 08:49 PM
  2. Getting wired - need help.
    By traindriver in forum Car Audio
    Last Post: 11-07-2006, 01:22 PM
  3. VK Digital Dash Km/ph gauge doesnt work!
    By A-TEAM AUTOMOTIVE in forum VB - VK Holden Commodore (1978 - 1985)
    Last Post: 09-04-2006, 10:33 PM
  4. dash lights dont work
    By simba1 in forum VN - VP Holden Commodore (1988 - 1993)
    Last Post: 30-11-2005, 05:49 PM
  5. Wired!
    By daggett in forum VT - VX Holden Commodore (1997 - 2002)
    Last Post: 02-11-2004, 03:17 AM
