Results 1 to 13 of 13
Thread: vp overheating :(
    RIC_VP's Avatar
    RIC_VP is offline [HEKT1K]
    VP Executive
    Sep 2007
    Exclamation vp overheating :(
    hey guys
    driving home today from a mates house, about 5 minutes from my joint, the temperature gauge was very high, almost to the top. when i stopped and opened the bonnet, i found the radiator cap to be stone cold.
    i went to open it, and as soon as i released a bit of pressure, BAM, massive amounts of water are being pumped into my overflow tank, which was previously empty. it just kept on pouring for ages, and it seemed like the water was boiling almost!
    has anyone has this problem before, or know what i can do to fix it? ive had stacks of cooling problems before (radiator gone, water pump gone etc..) so id really like to kill this problem before it gets out of hand!
    thanks heaps
    Ric
    it's getting kinda HEKT1K...
    UNKNOWN's Avatar
    UNKNOWN is offline DEFECTED
    95 VR SII BT1 5 Speed
    Jan 2008
    NW Adelaide
    Replace ur thermostat and do a cooling system flush.
    Shut up when I'm talkin' to you, you hear me, answer me!
    Tom_1569's Avatar
    Tom_1569 is offline Ecotech Power
    VS Ute - Daily, VT - Spare, 80 Series - W/E Bus
    Nov 2006
    Gippsland - VIC
    Yep thermostate, may even pay to replace the cap aswell.
    Quote Originally Posted by alien View Post
    I have been hit by oil badly once while in Army uniform on a massive roundabout that doesn't exist anymore. Spun 180 degrees to face oncoming traffic.
    Cobez's Avatar
    Cobez is offline LS-EXUAL
    2004 S2 VY SS Ute
    Feb 2007
    I'll say thermostat too. Happened to my VP not long. They just seize up sometimes. A censor from Holden will cost you $15.
    Quote Originally Posted by wikky
    As already stated, mate you're an absolute gherkin strummer.
    RIC_VP's Avatar
    VP Executive
    Sep 2007
    ok cheers for that guys... i replaced the cap a while ago cos the same thing was happening then, only not as severely. i think it may be too tight? not sure
    will ring holden and find out about a new thermostat
    Tom_1569's Avatar
    Nov 2006
    Gippsland - VIC
    Did you replace it with the right cap? they have PSI ratings.
    vn calais, vs clubsport #137
    Jun 2005
    id change your cap and thermostat. and top the coolant up to the correct level this time..
    Morton's Avatar
    Fairstar the Funship
    May 2006
    New cap, new thermostat (don't forget your thermo housing gasket), flush it twice and bleed when you're done.
    The 1972 HQ Kingswood
    PaRaDoX's Avatar
    PaRaDoX is offline boosted!
    Forester GT, VT S Supercharged, Supra Turbo
    Apr 2005
    Melbourne, Victoria
    yeah, its a blocked thermostat, you can usually tell by feeling the top radiator hose, if its coldish then its blocked or the radiator is but ususally the thermostat
    LowVp's Avatar
    LowVp is offline VP nut
    VP Ute 3.8T M5
    Aug 2005
    Ipswich, Qld
    Quote Originally Posted by RIC_VP View Post
    hey guys
    thanks heaps
    Ric
    its low on water and the water thats in there has turned to steam and when water is under pressure it raises the boiling point so when you release the pressure you have all that water at a higher them that instantly wants to expand hence it coming out as soon as you popped the cap
    vnv8driver is offline Banned
    304 Calais
    Aug 2007
    Up your mum
    everyones just said thermostat? what about thermo fan not engaging, operation of the water pump fins or a possible blockage?
    Mate when you squeeze the radiator hose (when its warmed up) is it stiff or can you squeeze it easily? also with the radiator cap off, can you see the coolant circulating through the radiator?
    Jun 2005
    KiWi1's Avatar
    KiWi1 is offline 11.00@126 Miss dat ****
    Dead 11sec VX SS, Defected VP Ute
    May 2008
    HIGGINS RACE DEVELOPMENTS
    Quote Originally Posted by vn calais manual View Post
    start with the simplest things.
    HaHA so true, but he has a point. Was the thermo fan running wen ya pulled over? As for the pouring into the overflow, it obviously was built up with pressure. Should of checked the top hose wasnt rock hard. Luckily you didnt get burnt
    Do as everyone said, but make sure you bleed the system just at the thermostat housing via the screw. Also give ya engine a good doin over with the hose when the thermostat housing is off. Just make sure you remove the bottom hose LOL
    Simon
LinkBacks (?)
  1. 03-06-2008, 01:00 PM
  1. Air Con and Almost Overheating
    By Feral01 in forum VN - VP Holden Commodore (1988 - 1993)
    Last Post: 21-10-2010, 04:03 AM
  2. Vn Overheating
    By SV3600 in forum VN - VP Holden Commodore (1988 - 1993)
    Last Post: 15-10-2009, 03:49 PM
  3. Overheating!
    By nicko451 in forum VY Holden Commodore (2002 - 2004)
    Last Post: 11-10-2007, 12:13 AM
  4. overheating
    By The Darkness in forum VR - VS Holden Commodore (1993 - 1997)
    Last Post: 04-12-2006, 08:11 PM
  5. overheating vh slx
    By white vn ss in forum VB - VK Holden Commodore (1978 - 1985)
    Last Post: 27-02-2006, 05:24 PM
