Results 1 to 16 of 16
Thread: doing fuel filter, what do i need?
    pow3rslave's Avatar
    pow3rslave is offline DoNothing Member
    VP 5.0L
    Oct 2005
    eastern subs, vic
    Default doing fuel filter, what do i need?
    ok, so after my cars stalling/speedo breaking (now all fixed) i figured i should do my fuel filter too.
    so i made a trip to ricerbarn and grabbed a ryco filter, about 30 cm of fuel hose and 4 hose clamps.
    i've got sockets and all that, but is there anything else i'll likely need to get before i start this.
    also should i run injector cleaner afterwards and if so whats a decent brand?
    VN_Luke's Avatar
    VN_Luke is offline ƃuoɹʍ ʇsnɾ sı sıɥʇ
    VT, RB30EST VN
    Mar 2005
    just make sure you have a couple of rags ready to catch fuel running down your arms towards your armpits when you take off the lines for the current filter
    It should be a matter of:
    - de-pressurising your fuel lines (run car with no fuel pump relay/fuse till it stops, then a bit more)
    - jacking up the back drivers side of the car? (if memory serves me correctly) and jack-stand or something
    - slide under car with rags a flathead and/or a phillips head screwdriver
    - locate old fuel filter, undo hose clamps, remove hoses (and watch the fuel in your eyes/on your arms )
    - remove old fuel filter (wrap in rag first or you'll get fuel everywhere )
    - fit new filter and replace hoses + clamps (make sure it's facing the right way)
    - lower car etc (jump out from under it first )
    - remember to plug the fuel pump relay & fuse back in
    - prime the lines a few times by hitting the ignition
    and you should be ready to roll! (have a shower or two before you go out or you risk being complimented on your gasoline perfume all night!)
    I personally don't really believe in injector cleaner... if you believe your injectors are dirty, take them out and get them properly cleaned!
    let us know how you go!
    Reaper's Avatar
    Reaper is offline Tells it like it is.
    E3 Senator Manual, VP SS
    Aug 2004
    Quote Originally Posted by pow3rslave View Post
    A jack, axle stands, screw drivers and a raincoat.
    Reaper
    Reapers Black VP SS
    0-60 mph = 5.39 Sec, 2.30 60'
    Quote Originally Posted by skruba View Post
    practice makes perfect dude i was (still am) my bros guinea pig,he has been tattooing for near 2 years.
    pow3rslave's Avatar
    VP 5.0L
    Oct 2005
    eastern subs, vic
    no sweat, i'll have a crack, then a celebratory cigarette and let you know if anything goes wrong
    Not_An_Abba_Fan's Avatar
    HSV Senator VTII
    Aug 2006
    Bunbury, WA
    Take the rhr wheel off and you won't have to get under the car. You can reach it through the wheel arch.
    Visit my Facebook page
    PaRaDoX's Avatar
    PaRaDoX is offline boosted!
    Forester GT, VT S Supercharged, Supra Turbo
    Apr 2005
    Melbourne, Victoria
    goggles....
    rubber gloves
    the fuel usually runs up your arm into your arm pits and burns lol
    but fuel in the eyes is the worst, once i took off my fuel reg, forgetting to depressurise it, BANG 40psi in the eyes of fuel.. i went blind for a good day.....
    yeah i removed the relay for my fuel pump and it never stalls luke, just take a line off in the engine bay then put it back on :P so you dont get squirted
    '92 HSV VP GTS
    Apr 2005
    SE Queensland
    PaRaDoX's Avatar
    Apr 2005
    Melbourne, Victoria
    Quote Originally Posted by PaRaDoX616 View Post
    goggles....
    rubber gloves
    im quoting my self....
    pow3rslave's Avatar
    VP 5.0L
    Oct 2005
    eastern subs, vic
    yeah so i did this today, not sure when the old one was last done, because it was genuine holden, and i haven't been for a service at a dealership for ages, so i think it's been a while.
    just a tip, fuel in the eyes hurts, like really hurts.
    i wore safety glasses, but pool goggles might have been better,cos it just sprayed and then ran into my eyes.
    in hindsight if i'd had time to think it would have been the ideal moment to yell "my eyes, the goggles do nothing" but i was too busy walking into a picket fence on the way to the tap.
    '92 HSV VP GTS
    Apr 2005
    SE Queensland
    LMAO, yeah, need to to make sure your face is out of the range of the fuel line.
    Jun 2005
    lol i laugh when i imagine someone running away from a jacked up car doing that.
    1995 Manual HSV Clubsport
    1991 Supercharged VN Berlina
    Morton's Avatar
    Fairstar the Funship
    May 2006
    Yeah, goggles are really useless. They do nothing. All they do is stop your hand getting to your eyes when you spill
    Having changed four fuel pumps and a handfull of fuel filters myself, I can tell you the best thing to do is just live with it. I've had fuel everywhere. Ears, eyes, mouth... these days I check leaks by tasting them to tell what they are.
    Best part about getting petrol all over your body, is that it washes off much easier than transmission fluid, and doesn't smell as bad as coolant. The petrol mixes in with the grease and it all comes off together. Awesome times. Hope you had fun, pow3rslave!
    The 1972 HQ Kingswood
    VP Executive R-spec
    Jan 2005
    Whats up with you guys and fuel. I seem to change filters with no fuel getting on me ?? hacks :P
    '92 HSV VP GTS
    Apr 2005
    SE Queensland
    Quote Originally Posted by greenfoam View Post
    Jase you old fart, its spelt HAXORZZZ
  15. #15
    pow3rslave's Avatar
    VP 5.0L
    Oct 2005
    eastern subs, vic
    i was just trying to chrome, but i'm just really bad at it
  16. #16
    Morton's Avatar
    May 2006
    Yeah, well... for a start you'd need paint to do that.
  1. fuel filter
    By adsVN in forum VN - VP Holden Commodore (1988 - 1993)
    Last Post: 14-07-2010, 05:53 PM
  2. Where is the fuel filter ???
    By sash in forum VZ Holden Commodore (2004 - 2006)
    Last Post: 13-01-2008, 08:44 PM
  3. Fuel Filter
    By StillDreaming in forum General
    Last Post: 14-01-2007, 02:50 PM
  4. fuel filter
    By JoeCamel in forum VR - VS Holden Commodore (1993 - 1997)
    Last Post: 29-01-2006, 08:01 PM
  5. Fuel Filter
    By bizzo in forum VR - VS Holden Commodore (1993 - 1997)
    Last Post: 25-05-2004, 09:48 PM
