Results 1 to 10 of 10
Thread: knocking noise
    VN SS 5.0
    Aug 2007
    Default knocking noise
    i can hear my lifters ticking like a bitch but when idling i can hear like a really bad knocking noise and also when u rev it quickly.
    iv changed the oil recently to 30w 60 hpr 30.
    still knocks and oil light comes on after a about 15 minutes of driving at idle.
    anything to solve this or should i be getting new lifters soon?
    would this stop not only the ticking but the knocking? and maybe get correct oil pressure? so the light would stop coming on?
    Blown V6 Hatch's Avatar
    Blown V6 Hatch is offline Too many projects.....
    VN Calais 5.0, UC Torana hatch 383, WB Ute 5.0
    Jun 2005
    Cowes, Phillip Island
    Sounds like you have an oil pressure issue mate.....Could be a blocked oil pick up. How long has it been since the oil change?? Holden V8's have been known to not pick up the oil after an oil change! First thing is first, you need to get a manual oil pressure gauge and check what sort of oil pressure it has. Don't run it long, an engine with low/no oil pressure will destroy itself in minutes! Although, i would say the damage is already done.....
    accentstencil's Avatar
    WH II Caprice, 5.7
    Jun 2005
    Eschol Park, Sydney
    It could be the oil pump has insufficient pressure due to a blockage or the pump itself.
    Too late again.
    MY RIDE
    PaRaDoX's Avatar
    PaRaDoX is offline boosted!
    Forester GT, VT S Supercharged, Supra Turbo
    Apr 2005
    Melbourne, Victoria
    Quote Originally Posted by sebstenator View Post
    *shudders*
    VN SS 5.0
    Aug 2007
    iv changed the oil a few weeks ago since i put the engine back in with other oil that wasnt too good. im thinking i should replace the oil pickup soon. the oil pumps fine. i checked it.
    cheers for that.
    Jun 2005
    Replace the oil pick up soon?? Are you crazy mate?? You realise what no oil pressure does to an engine.....Keep driving it and it will be dead very soon! But, like i said the motor is more than likely stuffed already.
    Just had a look at your ride thread, when you had the motor out did you clean any gunk out of the valley etc.??? If so, thats what has caused the problem. All that gunk will have gone into the sump and clogged the oil pick up!
    I think you will be up for a rebuild......
    89 VN Exec, 94 VR SS
    Dec 2007
    You live in Perth eh, you wouldnt happen to live around the north like Joondalup or so ?
    VN SS 5.0
    Aug 2007
    Dec 2007
    VN SS 5.0
    Aug 2007
    sweet. mite see you around some time aye lol
  1. VR Knocking Noise.
    By AussieHolden in forum VR - VS Holden Commodore (1993 - 1997)
    Last Post: 08-10-2006, 07:27 PM
  2. knocking noise VR
    By reckless in forum VR - VS Holden Commodore (1993 - 1997)
    Last Post: 13-01-2006, 05:43 PM
  3. knocking Noise
    By fudlop in forum VT - VX Holden Commodore (1997 - 2002)
    Last Post: 28-12-2005, 06:02 PM
  4. VP Knocking BAD noise
    By com123 in forum VN - VP Holden Commodore (1988 - 1993)
    Last Post: 23-10-2005, 09:45 PM
  5. Knocking noise
    By tkaragia in forum VR - VS Holden Commodore (1993 - 1997)
    Last Post: 31-03-2005, 07:14 PM
