My L2 dash shat its self the speedo didnt work everything else did but the speedo, so i got another 1 of a mate and put it in and it works but when i get up to about 90-100, the needle goes down to 0 the pops back up to 100, is there any way i can fix this? i thought it might be a voltage problem like the sticky dash or something, so i might pull it out and resolder the volt thing:P but could it be something easyer any ideas thanx
~ VN POWER ~ Click the scales
A broken speedo sender fuse does that, check it
where would that be located, i checked the speed sensor and seems to be ok.
In the fuse box![]()
if your problem still exists, get under the car drivers side of the trans there a cylinder looking thing attached to it.. its screwed on so unscrew it, unplug it from the car and give the connections a good clean with WD40 or sumthing similar and there ur problem solved, unless ur speed sensors dieing.. and remember to screw it back on very tight mine was loose n the speedo was jumping n remember to clean it
laterZ
oh yea and it got nothing to do with a sticky tacho etc.. try that what i posted abovee and let us know how its going
