hey guys..
i have this problem when you give it gas its like its gonna stall??? say if you just push the gas quickly to say around 3rpm it would sound like its gonna stop??? never use to do it beforee??
its running with a vr coilpack near new leads with a clean pod filter..?
But after you stab the throttle it pauses right, then the revs kicks in? This happened to me twice, both exactly the same symptoms. First was a faulty fuel pressure regulator and second time was a dodgey coolant temp sensor.
yea thats right mack.. pauses for like a second or 2, so i should change the fuel regulator at first
