Results 1 to 18 of 18
Thread: Water ****ing out of engine
    VN 5 Speed
    Jun 2008
    Default Water ****ing out of engine
    Hey guys im new to the site, i just brought a manual vn s pac on sunday and the engine has a pretty bad flow of water from the front drivers side of the engine. It seems to be coming from around the extractor closest to the front of the car but its hard to see where its coming exactly
    thanks for any help guys much appreciated
    azkwazere is offline Ahhh Yes, Ahhh Yes....
    VP 5-SPD / 24-SPD Racer Hybrid
    May 2005
    .....SE Burbs
    Maybe you have a hole in the water jacket... You really need to be specific about where its coming from... Right hand extractor front is most likely to be a leak or crack in the front radiator hose rear the CAS... It might not be though!
    aZk.
    VN 5 Speed
    Jun 2008
    I cant see exactly where its coming from. I removed the steel pipe that goes to the back of the engine from the radiator but really cant see exactly where its coming from, hopefully tonight i will be able to remove everything else in the way and the power steering pump and have a better look.
    thanks again
    UNKNOWN's Avatar
    UNKNOWN is offline DEFECTED
    95 VR SII BT1 5 Speed
    Jan 2008
    NW Adelaide
    Heater hoses maybe?
    Shut up when I'm talkin' to you, you hear me, answer me!
    Cobez's Avatar
    Cobez is offline LS-EXUAL
    2004 S2 VY SS Ute
    Feb 2007
    Might possibly be the inlet manifold gasket, leaky hoses could be a number of things.
    Quote Originally Posted by wikky
    As already stated, mate you're an absolute gherkin strummer.
    May 2005
    .....SE Burbs
    Morton's Avatar
    Fairstar the Funship
    May 2006
    Cover the stuff in degreaser, wash it all off, blowdry and wipe it so it's all bone dry and clean, then get in there with a BRIGHT floodlight and turn the car on. Watch to see where the fluids come from.
    You'll have to find out exactly what the water is coming out of before we can help
    The 1972 HQ Kingswood
    May 2005
    .....SE Burbs
    Quote Originally Posted by Cobez View Post
    doubt it will be a manifold gasket as the physics of it dont add up... The water will flow into the engine rather than out of it.. It might be but its very unlikely.
    Ill put my money on hoses or wlsh plugs.
    aZk.
    vs commodore V6 S2
    Nov 2006
    maryborough QLD
    pow3rslave's Avatar
    pow3rslave is offline DoNothing Member
    VP 5.0L
    Oct 2005
    eastern subs, vic
    VN 5 Speed
    Jun 2008
    accentstencil's Avatar
    WH II Caprice, 5.7
    Jun 2005
    Eschol Park, Sydney
    No tips on how to replace cause I've never done one but you are lucky it is easy to get at. Looks like it's been leaking for some time, very rusty. A good reason to use coolant at the correct ratio.
    Ok, just checked my Gregory's.
    Using a punch and hammer, tap the welch plug on it's outer circumference into the opening
    Grasp the edge of the welch plug with multigrips and lever it out.
    Thoroughly clean he opening.
    Lightly smear the opening and the edge of the welch plug with a suitable joining compound , such as (Permatex No 2)
    Place the new welch plug onto the opening and using a large socket that fits inside the rim of the plug, tap it squarely into the opening.
    MY RIDE
    VN 5 Speed
    Jun 2008
    thanks mate i cant seem to et the rihgt size replacement welsch plug, i got a 32 mm and its too small, so i got the next size up and its too big and cant get it in there, is it imperial or something?
    Dumped IRS VS Acclaim 3.8, VR Stato Caprice 5.0
    Nov 2007
    Hatton Vale. country at its best. :)
    Quote Originally Posted by accentstencil View Post
    yep that is the culprit alright. i just had mine done but i had the left hand side welsh plug go on me.. i done the safest thing and got all the welsh plugs done just to be sure.. about $500 later and no more leaks
    cheers with the job ahead of you bro...
  15. #15
    Nov 2007
    Quote Originally Posted by pranksta View Post
    might be an 1 1/2 inch plug if memory is right just measure the hole inside to inside then head to repco or supacreep to bet one for about $6
  16. #16
    VN 5 Speed
    Jun 2008
    ended up beging 1 and 1/8 for anybody looking, thanks for the help guys changed both of them, just hoping the block ones hold out for a while!
    thanks again
    paul
  17. #17
    Calaber's Avatar
    Calaber is offline Nil Bastardo Carborundum
    CG Captiva SX
    Nov 2007
    Lower Hunter Region NSW
    Pranksta
    If you had to replace two welsh plugs, the chances are that the rest are about to go on you. My VN needed every bloody plug replaced because VN's only had mild steel plugs but from VP on, they were stainless steel from the factory. If the coolant was not maintained properly, the VN plugs rust like blazes. There are three on each side of the block, and the rear one on the driver's side is a proper mongrel to replace in the car becasue the steering shaft prevents you from getting a clean straight hit on the new plug to drive it fully home.
    Then, to cap it off, there are two more plugs are the rear of the block, in front of the flywheel. To replace them, the trans and flywheel need to be removed. And they rust just as badly as the others. I replaced the side ones, then had the rear ones cark it. Flogged the car- I'd had enough of the VN's miserable brakes and handling by then and couldn't be bothered with the effort involved to replace two crappy little welsh plugs.
  18. #18
    VN 5 Speed
    Jun 2008
    yea i know, it was only one that needed to be replaced but i thought i better replace the other while i was at it so i did, i know the bottom ones are hard im just hoping they hold out, i just brought the car and it had been sitting for 8 months with straight water and didnt tell me about it, but yeah i hope it holds out because i cant afford to change the others yet
  1. water disappearing - water pump - how to change?
    By vh-holden in forum VR - VS Holden Commodore (1993 - 1997)
    Last Post: 28-07-2008, 01:30 AM
  2. Using Water
    By lgnd3800 in forum VR - VS Holden Commodore (1993 - 1997)
    Last Post: 15-02-2008, 05:23 PM
  3. air con water?
    By mark_1000 in forum VN - VP Holden Commodore (1988 - 1993)
    Last Post: 07-01-2007, 10:18 AM
  4. water pump behind engine bloack
    By 3800_man in forum VN - VP Holden Commodore (1988 - 1993)
    Last Post: 08-07-2006, 04:22 PM
  5. car covers . water proof vented vs water resitant non vented
    By justbad4you in forum VT - VX Holden Commodore (1997 - 2002)
    Last Post: 08-10-2005, 01:20 PM
