Results 1 to 22 of 22
Thread: Using way too much petrol in my vp
    VP executive V6
    Jun 2008
    Default Using way too much petrol in my vp
    now it only a 3.8L, no pod at the moment, and it uses a full tank of juice and i only do about 300km, now i have changed the fuel pump, a new oxy sensor when it in about 2 months ago when i started to have this problem, now do theses car have an auto choke, as i have been told it might be that, but sa im not sure i have to ask, what can this be caused from, thanks
    5sp VN Executive1988, VX SS 6sp
    Apr 2006
    canberra
    Maybe your foot has got heavier? If you have a bit of a heavy foot 300kms out of a tank sounds about right. I have got worse.
    Australia. Love it or leave it
    azkwazere is offline Ahhh Yes, Ahhh Yes....
    VP 5-SPD / 24-SPD Racer Hybrid
    May 2005
    .....SE Burbs
    Do you have flat tires?
    Do you have a fuel leak?
    How do you drive?
    Hows your air filter?
    Do you have a 30 litre tank(sif)?
    Any mods?
    What sort of driving do you do?
    aZk.
    vnv8driver is offline Banned
    304 Calais
    Aug 2007
    Up your mum
    300kays out of a 63 litre tank is common on the average v6. if your motors in good condition and hasnt got 300,000+ km/s, get your motor de-carboned.
    VX SS II 6.3L/M6
    May 2005
    Quote Originally Posted by vnv8driver View Post
    Thats pretty poor, i do feel sorry for you guys.
    Im currently getting around 700kms per 60L in my VR Wagon. It is manual which adds about 100-150kms, but ive done the following mods to improve fuel economy.
    Remove the bellmouth
    CAI, About $60 from ebay
    Exhaust system (Pacemaker extractors + CAT + Rear Resonator)
    Memcal Reprogramming
    New Spark Plugs, New Leads, New Coil Packs, VY Injectors (Straight swap over, cost $100), New Air Filter, New Fuel Filter, New Oil Filter, Oil Change (High quality oil), New O2 Sensor, 18" Mags running at 42psi
    So yeah, If i push really hard i get 350-400kms from a single tank (That includes flat chat 0-100 from every set of lights, in about 8s) High speed driving through mount Dandenong etc etc.
    Again being manual, that saves a bucket load of fuel compared to the Autos, but i would still expect 550-600kms a tank.
    304 Calais
    Aug 2007
    Up your mum
    VP Executive R-spec
    Jan 2005
    An average VP V6 auto should do a little over 600 ks from a tank in a pretty much straight line on the highway, which you can increase to 800 ish with the mods feistl has suggested. No use doing those until you can make 600 stock tho because it must have issues
    VX SS II 6.3L/M6
    May 2005
    Quote Originally Posted by greenfoam View Post
    I agree, 300-400kms indicates something seriously wrong. Has the OP checked the error codes?
    wagons get 80 litre tanks dont they?
    Its either 60L or 65L, Most ive ever put in has been 63L. When i work out my economy i measure the amount of fuel filled up compared to the kms traveled. Its generally not a good idea to run the car very low on fuel. Can easily kill the fuel pump
    VP executive V6
    Jun 2008
    well to all that want to know, i dont have a lead foot as im only on one point, and i have changed the o2 sensor and the fuel pump, im woundering if anyone knows any good machanics to take it too to have them look at it, im in geelong in victoria, cheers
    FXST01's Avatar
    FXST01 is offline The Grey Man
    VP V6 Auto Sedan
    Jun 2005
    El-Arish-Shamal-Sina-Egypt
    New plugs/leads
    did you change the fuel filter?
    new air filter
    when was the last oil change?
    Illegitimi Non Carborundum
    LowVp's Avatar
    LowVp is offline VP nut
    VP Ute 3.8T M5
    Aug 2005
    Ipswich, Qld
    i have found when the oil is near due for a change my mileage gets worse. also here is a little kicker my wife and i work roughly in the same area of brisbane but i have to go an extra 15min, so about 26km either way to home.
    i'm driving my VP 5 speed ute, 3.45 diff, stock engine, chiptorque chip, no extractors and a 3" exhaust with a resinator for a muffler (for turbo setup), and the turbo removed and i drive with a bit of spirit i use 50 bucks per week and can last me near 6 days to and from work
    wife on the other hand has a 2002 V6 Camry 3L auto traveling say 6km either way less then me drive like a grandma in a stock camry apart from wheels and suspension uses near on 70 bucks per week if not a touch more.
    but come out onto the highway and the camry gets a **** load better economy with a high speed cruise with premium in the tank
    88GreenVN's Avatar
    88 Green VN Wagon 389,000kms
    Jun 2006
    Deep South - VN Country
    Temp sensor telling the ecu the car is cold so it pumps more fuel in - my 2 bob's worth.
    and 3 Dangerous non ABS VN's
    crazyspoon05's Avatar
    crazyspoon05 is offline Penguin Whisperer
    The 'Bizta' VNVPVR Wagz
    May 2006
    68 litres....
    300 is pretty crappy, even my wagz gets 400+ out of a tank driving to and from work and with only occassional highway miles
    If ignorance is bliss why aren't there more happy people around ?
    304 Calais
    Aug 2007
    Up your mum
    i rememmber hearing either 70or 80 but couldnt remeber, the vn wagons had the 80's im sure, thats why i thought the later models might as well.
  15. #15
    May 2006
    V8 Sedans had the 80 litre tanks, all VN-VS wagons had the 68 litre tank
  16. #16
    HoZy's Avatar
    HoZy is offline //There Ain't No Rest For The Wicked...
    BMW E39 540i
    Jul 2004
    S/E Subs, Melb
    hmm sorry to hijack, this thread makes me think i should do an error code test... lately my fuel average has gone from 14ltr/100km city. to 20ltr/100km..... pain in the ass..
    Quote Originally Posted by garth
    well if it isnt mr i only have temp bans. how long you intending on staying this time hozy.
  17. #17
    padrickz88's Avatar
    padrickz88 is offline Rick =]
    VN V6, nothing special
    Dec 2005
    sunshine, melbourne
    Quote Originally Posted by 88GreenVN View Post
    i went into supercheap and they only know them as "water temp sensors"..... just so people know what to ask for
    **** thats pretty bad hozy, on the freeway when my o2 sensor was dead i was getting about 18L per 100, and thats all granny lucky ive changed that YAY!!!
  18. #18
    Full Spectrum's Avatar
    Full Spectrum is offline Customize your life.
    2000 Berlina V6.
    Dec 2003
    Melbourne's West.
    Blog Entries
    I was getting a few years back 240-270km on a full tank. Sometimes $30 would be gone in 30km.
    To ad onto size in tanks, My VP V6 has a 75L or something like that. Takes 68-71/L above red, But doesn't look like the size of the V8 ones but is larger then V6's i have seen. And has plenty on dints under it which would hurt capacity.
    Went over the car.
    Fuel Filter.
    Fuel regulator.
    O2 Sensor.
    Injectors.
    Spark plugs.
    Leads.
    Oil Change.
    Air filter.
    Cold Air intake.
    Changed T/B standard size.
    Even tossed in a exhaust system.. Cat was burnt out dead.
    Now get 450km local driving..
    Went to Shepparton last year down the highway over 150km still sitting on full.
    Quote Originally Posted by Yoda
    Do, or do not. There is no 'try'.
    <img src=http://forums.justcommodores.com.au/signaturepics/sigpic440_66.gif border=0 alt= />
  19. #19
    burnz's Avatar
    burnz is offline dah dut dut da dah
    2010 CRUZE Diesel
    Jun 2005
    springfield
    the most common problem is the vacumm hose on the MAP sensor, no error code's given.
    Research has shown that men usually sleep on the right side of the bed.
    Even in our sleep we happen to be right.
    Powered By Garrett
  20. #20
    VP executive V6
    Jun 2008
    is it worth putting a manual in it, i think im gonna do an engine change as i susspect the motor has done well over 350,000k even tho the speedo says it done 200,000. its had the heads done on it, the little stamp on the back of the motor. tells me that. what should i pay for a complete manual converson, whats too much
  21. #21
    1996 VS BT1 SS 5ltr original
    Apr 2008
    i am getting around 400kms to a 60-65ltr tank. After reading over a few of your comment i am going to change the o2 sensor and water temp sensor and see how i go. Hav already given it a major service so it doesnt need that.
  22. #22
    VQ Statesman 5.0 litre
    Jun 2008
    North Qld
    I have constantly got 11.9 to 13.5 out of my vp calais. A lot of highway k's i must admit but i just live driving it!..............Pete!
LinkBacks (?)
  1. 06-06-2008, 10:11 PM
  1. E10 Petrol?????????
    By struggo in forum VR - VS Holden Commodore (1993 - 1997)
    Last Post: 06-07-2008, 05:05 PM
  2. Which petrol is best?
    By CHARGEDVT in forum VT - VX Holden Commodore (1997 - 2002)
    Last Post: 22-01-2007, 02:43 PM
  3. does anyone else have gas/petrol
    By SYM35 in forum VR - VS Holden Commodore (1993 - 1997)
    Last Post: 19-08-2006, 04:18 PM
  4. Gas instead of petrol
    By kaner in forum General
    Last Post: 05-09-2005, 12:49 AM
  5. Which Petrol?
    By pooner01 in forum VB - VK Holden Commodore (1978 - 1985)
    Last Post: 12-01-2004, 11:50 PM
