Results 1 to 11 of 11
Thread: Help vn 5.0 blow by
    08 VE SSV M6
    Aug 2007
    Default Help vn 5.0 blow by
    i have a vn 5 litre and im having problems with the rocket cover breather hoses they let oil from the rocket covers leak into the throttle body which causes it to blow smoke would a oil catch can fix this or is there a better way to fix it any help would be great
    VP Executive R-spec
    Jan 2005
    It must have been to the moon and back a few times, I've not seen a 5 litre have any real issue with blow by yet and I've seen some with huge k's on them. It's just caused by worn rings so not much you can do about it apart from replacing the worn parts
    Blown V6 Hatch's Avatar
    Blown V6 Hatch is offline Too many projects.....
    VN Calais 5.0, UC Torana hatch 383, WB Ute 5.0
    Jun 2005
    Cowes, Phillip Island
    VP Executive R-spec
    Jan 2005
    Fussssssy buggers, maybe hes got the old school 60's/70's hoon thing going on. Green is nice
    08 VE SSV M6
    Aug 2007
    it has done 256000ks i replaced the standard hose from the rocker covers to the throttle body with clear hose and you can see that there is oil in the hoses have done a compression check and its all fine has had a freshin up rings,pistons,bearings and gaskets about 100000ks ago
    VS 355 Turbo, VN Calais 5L, VE SII SV6 Wag, Mirage
    Aug 2006
    Adelaide, SA
    do you still have the PCV valve hooked up? are the baffle plates behind the oil breather outlets on the inside of the rocker covers still there?
    08 VE SSV M6
    Aug 2007
    Aug 2006
    Adelaide, SA
    Possibly could be jammed but i don't think that would cause the proplems you are having....
    Who did the rings bearings etc when it was freshened up?
    vnv8driver is offline Banned
    304 Calais
    Aug 2007
    Up your mum
    08 VE SSV M6
    Aug 2007
    my mates god father he has builds race motors he said to put new pcv in but im not sure if that will work
    Aug 2006
    Adelaide, SA
    take the PCV valve off and try to blow in it both ways. one way should flow freely the other should not let air flow. this will soon tell you if its blocked or not.
  1. Blow Off Valve? Help?
    By Bubbaj247 in forum VT - VX Holden Commodore (1997 - 2002)
    Last Post: 11-02-2011, 10:01 AM
  2. How to blow 5k on a VN S1?
    By mulligan-can in forum VN - VP Holden Commodore (1988 - 1993)
    Last Post: 12-03-2007, 11:07 PM
  3. blow joke ;)
    By ssmate in forum Jokes/Humour
    Last Post: 21-11-2006, 07:03 PM
  4. will this blow my sub
    By lieos in forum Car Audio
    Last Post: 27-08-2006, 03:29 PM
  5. VX Blow off Valve.
    By substanceVX in forum VT - VX Holden Commodore (1997 - 2002)
    Last Post: 01-08-2006, 06:03 PM
