Results 1 to 22 of 22
Thread: Driver's door hard to close. Slamming pretty much necessary.. :(
    savage1987's Avatar
    savage1987 is offline fail champion
    LS1 VN + 304 VN
    Blackjack Champion!
    May 2005
    Default Driver's door hard to close. Slamming pretty much necessary.. :(
    Any common causes for this? It's really starting to give me the ****s, plus becuase you have to shut the door so damn hard one of the two screws that holds the inside door handle in place has torn free.
    Sam
    WTB: mulberry VN interior parts
    VN_Luke's Avatar
    VN_Luke is offline ƃuoɹʍ ʇsnɾ sı sıɥʇ
    VT, RB30EST VN
    Mar 2005
    get some correct-size torx bits, and adjust the striker on the B pillar.
    depending on how much of a perfectionist you are, it can take a few hours to get spot on
    can also get some graphite powder and lube up the latching mechanism in the door for nice and smooth operation
    azkwazere is offline Ahhh Yes, Ahhh Yes....
    VP 5-SPD / 24-SPD Racer Hybrid
    May 2005
    .....SE Burbs
    check it has all its hinge pins too...
    if you loose one it may fall out of alignment and then cause it to be hard to close...
    All else fails... fiddle more with latching mech.
    aZk.
    VN_Luke's Avatar
    VT, RB30EST VN
    Mar 2005
    ^^ valid point
    from what I understand the hinge pins can also 'warp' (i.e. even if they're there, they might let the door still hang down) - is the door fouling anything when it's closing?
    VN Ute
    Oct 2006
    the pins snap but stay where they are allowing the door to move around.... are very hard to get out when this happens, my door now swings on the hinge pin removal tool as it snapped off while i was trying to get it out,
    also if you have nice paint take the front gaurd off while messing with the pins or you may have some nasty scuffs (front doors only rears have better access)
    Japanese scientists have created a camera with such speed that they now can photograph a woman with her mouth shut!
    savage1987's Avatar
    LS1 VN + 304 VN
    Blackjack Champion!
    May 2005
    Quote Originally Posted by VN_Luke View Post
    Got torx bits already, any more info on the striker? The door isn't out of alignment, it doesn't hang down noticeably and isn't sticking out or in too far from the back door either...
    Quote Originally Posted by azkwazere View Post
    aZk.
    Think I'd have noticed if it didn't have all its hinge pins but ok... the door will locate properly, but only shuts to the first click until you really give it a shove. Just to clarify the problem a bit
    Nope.
    Quote Originally Posted by slo_firo View Post
    Maybe I'll just get brand new hinge pins, can you still get them? Might be worthwhile regardless of if this is the cause.. Rough price on new pins for all doors?? Checkstraps at the same time?
    VN Ute
    Oct 2006
    yea get em from holden only a couple of dollers each, the removal tool is about 20 i think, have to get that from a tool shop
    with my pin broken it didnt look that far out of alainment but i could lift the door slightly, it was probably only sagging by a few mm but just enough so it was a pain to close (i had to open and close the door for my mrs lol...)
    VN_Luke's Avatar
    VT, RB30EST VN
    Mar 2005
    yep - loosen the torx screws a little bit (so they're still more or less tight) then slide the striker around to wherever it should be.
    If it was my car (and the hinge pins were fine etc), I'd pull the striker towards the outside of the car by a few mm, then re-tighten the screws and see if door closes properly...
    VN S2 Berlina Wagon
    Apr 2004
    I replaced the two hinge pins on mine and it got a little better for a few weeks then it was back to its old annoying self. Might try the striker.
    VX 'S' S1
    Apr 2005
    South East,Victoria
    Try the cheap easy options first like spraying the door mechanism with CRC or WD40. If this fails then mark around the striker plate with a lead pencil then remove bolts and striker plate . Close the door and check the gaps aroung the door to see if it has sagged.A good way to check is check the style lines with door shut .They are the pressings on the lower door where the bump strips go or the top of the door just above the door handle to see if it is flush .If all is ok ,refit the striker plate making sure to use the pencil marking to line it up . Just nip the screws up so they just hold the plate in place then close the door .The front door should just sit proud of the rear door,The reason for this is that it reduces wind noise.The reason for not doing the striker plate up tight is when you shut the door the plate will align itself . Next open the door and tighten the plate up a bit more. Close the door with the door handle held up to check where the striker hits the door and adjust to suit
    savage1987's Avatar
    LS1 VN + 304 VN
    Blackjack Champion!
    May 2005
    Good advice guys, thanks. Will get onto this as soon as I have some spare time in daylight!! I think the striker may be a winner, but might do the pins anyway. Mechanic at work said just replace the whole lot of the hinges and pins, but he's more of a ford man.. not sure if you even can replace the hinges in a VN?? Haven't looked properly yet.
    Dayvo.. bump strips are long gone but I know the pressings you mean. Good tip. Also I didn't know the front should sit proud, thanks for pointing that out! I know it wouldn't be by much.
    Sam
    VN Ute
    Oct 2006
    Quote Originally Posted by savage1987 View Post
    Sam
    hinges are welded to the body and door so the hinge is the only part to fail in that department - unless you have rust issues
    VX 'S' S1
    Apr 2005
    South East,Victoria
    Thats right , they are welded on but sometimes when when the doors are aligned in production the welds crack . If you are going to replace the pins i posted a thread in the VL section which is basicly the same as the Vn VP
    '92 HSV VP GTS
    Apr 2005
    SE Queensland
  15. #15
    Tom_1569's Avatar
    Tom_1569 is offline Ecotech Power
    VS Ute - Daily, VT - Spare, 80 Series - W/E Bus
    Nov 2006
    Gippsland - VIC
    Quote Originally Posted by Dayvo View Post
    VN are different to VL, as I learnt caus i described the way to remove a VN pin in the VL thread, so you can go find that if you like.
    The VN should be at home tonight, so if its light ill take a photo of how to remove them. Just get vice grips on the pin tight, so its squeezed in, then hammer the vice grips so remove the pin, its quite simple and doesnt take long at all. The front doors are a bit hard to do, but if you remove the middle one (it stops the door opening as far as possible) you should be able to open the door enough to swap the pins, just have a mate or a jack hold the door.
    Quote Originally Posted by Mack View Post
    You can enter your car into the "Door Slammer" category!
    LMAO
    Quote Originally Posted by alien View Post
    I have been hit by oil badly once while in Army uniform on a massive roundabout that doesn't exist anymore. Spun 180 degrees to face oncoming traffic.
  16. #16
    VX 'S' S1
    Apr 2005
    South East,Victoria
    Quote Originally Posted by Tom_1569 View Post
    LMAO
    just a little pointer , if you remove the the part that stops the door opening as far as possible , Just be carefull that you don't oprn the door too far incase the front guard puts a crease in the door
  17. #17
    savage1987's Avatar
    LS1 VN + 304 VN
    Blackjack Champion!
    May 2005
    Thanks guys, I'll do the hinge pins as soon as I can, and play around with the door striker as well.
    Had a quick look for that thread you mentioned and couldn't find it... it doesn't matter though, I work at a wrecker so should be able to figure it out!!
  18. #18
    savage1987's Avatar
    LS1 VN + 304 VN
    Blackjack Champion!
    May 2005
    Well I've been lazy, finally got around to having a close look at the door yesterday and it is the hinge pins. I think I'll get a price from Holden tomorrow and see how it goes, I've got some work to do on the 5L as well though, it took a bit of a hit yesterday.
    Sam
  19. #19
    savage1987's Avatar
    LS1 VN + 304 VN
    Blackjack Champion!
    May 2005
    Hinge pins x 8 came to $32 or so from Holden, so they'll be on in 3 weeks when I'm back from Paris... VN's getting a greenfoam tune while I'm away as well
    Sam
  20. #20
    88GreenVN's Avatar
    88 Green VN Wagon 389,000kms
    Jun 2006
    Deep South - VN Country
    If you have slammed the door on the seat belt buckle at some point this will move the stricker in just a smidge and yep doors hard to close after that. Takes 5 mins to loosen the stricker a bit and tap out a small amount. Hint undo 1 screw all the way loose and just undo the second one enough so when you tap it (the stricker) with a small hammer it moves but does not flop around like a dead fish. Then do all the way tight again before closing the door.
    And yes I have adjusted plenty of doors in my time as my dad had a panel shop in the driveway for 30 years and fixed hundres of cars.
    and 3 Dangerous non ABS VN's
  21. #21
    VT
    Apr 2005
    QLD
  22. #22
    savage1987's Avatar
    LS1 VN + 304 VN
    Blackjack Champion!
    May 2005
    Door seals are fine. Brown, but fine. lol they're one of the last remaining brown trim pieces in the car. I'll try moving the striker out that tiny bit at the same time and see how we go. Should end up pretty well perfect
    Sam
  1. Help! Glue behind trolleybasher strip won't come off driver's door!
    By savage1987 in forum VN - VP Holden Commodore (1988 - 1993)
    Last Post: 31-12-2006, 04:11 PM
  2. Lock on driver's door, not opening fully???
    By ruso in forum VT - VX Holden Commodore (1997 - 2002)
    Last Post: 19-07-2006, 05:57 PM
  3. passenger side door doesnt close
    By frenzal_tom in forum VR - VS Holden Commodore (1993 - 1997)
    Last Post: 24-03-2006, 10:21 PM
  4. Door wont shut/close
    By VS1Tonner in forum VR - VS Holden Commodore (1993 - 1997)
    Last Post: 25-09-2005, 02:46 PM
  5. Replacing Window Seal on Driver's Door
    By Jamesp in forum VN - VP Holden Commodore (1988 - 1993)
    Last Post: 20-09-2005, 02:57 PM
