Results 1 to 8 of 8
Thread: Both my tail lights and brake lights have stopped working.
    VN Berlina
    Jun 2008
    Exclamation Both my tail lights and brake lights have stopped working.
    HELP!! Both my tail and brake lights have stopped working but my spoiler light is working when i brake. I have checked the fuses and changed the fuse for the brake lights and swaped relays. Also I have checked the earth is connected properly and checked that the wiring harness's are connected properly. On the weekend I went over a sign lying on the road and a peice of wood got stuck under my middle center of the car and I had to yank it out to remove it. Can someone help me with this? Could the wood getting lodged under my car have any relation to the problem, because the lights stopped working around the time of the incident with the sign on the road.
    Stuballs
    '97 VS Commodore + '98 E36
    Apr 2005
    Don't mean to seem like Mr. Captain Obvious
    ..but you didnt mention anything about changing the bulbs
    have you checked?
    ..'cause the the filament might have broke from the shock while you stomped on the brakes going over that sign
    VN Berlina
    Jun 2008
    Yes sorry i have changed the bulbs and also in addition to what i wrote the reversing lights all work. I casually ran over that sign cos it was to late it was only a few stakes laid out flat. But as I wrote one got lodged in under my car.
    VP executive V6
    Jun 2008
    when i got my car put on the road, my lights wernt working at all either, i had to replace both wireing looms, pain in the butt but had to be done, now i dont have a problem with it
    VN Berlina
    Jun 2008
    pow3rslave's Avatar
    pow3rslave is offline DoNothing Member
    VP 5.0L
    Oct 2005
    eastern subs, vic
    if you've got water in your boot recently there could be buildup of scrunk on the terminals of the bulb holders, tried white spirits or something on them?
    KiWi1's Avatar
    KiWi1 is offline 11.00@126 Miss dat ****
    Dead 11sec VX SS, Defected VP Ute
    May 2008
    HIGGINS RACE DEVELOPMENTS
    STEALTHY™'s Avatar
    STEALTHY™ is offline So Wet For You!
    VP Calais International, VP Berlina LX Wagon
    Jan 2005
    SA - The Roadworks State
    If it was just the brake lights, i'd say its the switch on the pedal.
    Being all lights, i guess its electrical. Try a new set of looms, and see if it works, and sounding obvious, check the fuse
    Quote Originally Posted by davway
    Improved Suspension Reduces Handling!
    Quote Originally Posted by JONNNNOOOOO!!
    cheers sexy
  1. brake lights not working
    By george vx in forum VT - VX Holden Commodore (1997 - 2002)
    Last Post: 01-12-2007, 03:25 PM
  2. Help - brake lights not working!
    By matty193 in forum VR - VS Holden Commodore (1993 - 1997)
    Last Post: 19-06-2006, 11:10 AM
  3. Brake lights not working
    By kopper69 in forum VR - VS Holden Commodore (1993 - 1997)
    Last Post: 10-09-2005, 04:47 PM
  4. Tail Lights not working properly
    By Bundybeardan in forum VT - VX Holden Commodore (1997 - 2002)
    Last Post: 05-07-2005, 03:59 PM
  5. Vn Brake Lights Not Working
    By filter in forum Electrical Wiring / Questions
    Last Post: 15-03-2004, 08:01 AM
