Results 1 to 12 of 12
Thread: VT Rear Brakes To VN?
    Dan355's Avatar
    Dan355 is offline Go THE SS's
    Street Legal 355ci VN SS - Daily: VP SS
    May 2006
    Default VT Rear Brakes To VN?
    Hey, Just want to know whats involved with fitting rear vt brakes to a vn?
    vnv8driver is offline Banned
    304 Calais
    Aug 2007
    Up your mum
    What's on the front? just remember that 70-80% of your braking is at the front end, so itf the front is stock get that done first.
    azkwazere is offline Ahhh Yes, Ahhh Yes....
    VP 5-SPD / 24-SPD Racer Hybrid
    May 2005
    .....SE Burbs
    No point... same brakes dude....
    VT Rears are not any better....
    That and they wont fit anyway!
    aZk.
    Dan355's Avatar
    May 2006
    I have a 330mm PBR kit on the front with VT master/booster to correct brake bias. Rears at the moment are just slotted/cross drilled. Need it engineered (brake test) as im keeping the rears standard. I wont need to spend cash on the brake test if i can use the vt rears, hence my question. Cheers!
    AirStrike's Avatar
    AirStrike is offline Site Administrator
    2009 G6ET
    Jun 2003
    Quote Originally Posted by Dan355 View Post
    You can fit them mate, you just need the Harrop backing plates and handbrake setup. If you are going to the trouble of doing this though I would look at the HSV 315mm setup mate, which is what came with the HSV 330mm fronts.
    Selling FG G6E Turbo and buying a N/A Supra
    Dan355's Avatar
    May 2006
    Ah yea. I wonder how that would go engineering wise? I read that it adjusts the track by 6mm?
    AirStrike's Avatar
    2009 G6ET
    Jun 2003
    Not sure on the exact amount, but yes it will alter the rear track. Maybe email Harrop for some info.
    1991_Vn2nV's Avatar
    91 VN Berlina & 03 VY Berlina
    Mar 2006
    Gumeracha, Adelaide Hills
    They may want 315mm rears as well for engineering anyway as thats what came with the 330mm fronts on the HSV's as Airstrike said. 330mm fronts with stock sized rear brakes wouldn't impress the engineer much I wouldnt think.
    VP Exec
    Jun 2005
    Because it's not a factory option on the car it will need the report regardless.
    What is used on VT- one tonners?
    immortality's Avatar
    VN3.8 5spd/VSII3.8/VH5.0
    Apr 2006
    Auckland NZ
    i think surfwagon has this on his wagon. i think he even did a "howto"
    check this http://forums.justcommodores.com.au/...rear-axle.html
    Body by Holden, Soul by Brock
    the Legend will live forever
    Dan355's Avatar
    May 2006
    Quote Originally Posted by Cheap6 View Post
    A report is needed but not a test.
    Dan355's Avatar
    May 2006
    Quote Originally Posted by immortality View Post
    Cheers mate. I think ill go with just the standard rears. Not very keen on increasing my track + getting a report for it would be a headache.
  1. Using Harrop Adapter to fit VT-VY rear brakes to VL-VS solid rear axle
    By Surfwagon in forum Holden Commodore How-To's
    Last Post: 26-11-2007, 04:46 PM
  2. Rear brakes squeeling
    By 300zx in forum VR - VS Holden Commodore (1993 - 1997)
    Last Post: 22-01-2007, 08:31 AM
  3. disc brakes rear end
    By potshots007 in forum VB - VK Holden Commodore (1978 - 1985)
    Last Post: 15-11-2005, 02:51 PM
  4. vt rear brakes
    By briannon2002 in forum VR - VS Holden Commodore (1993 - 1997)
    Last Post: 11-08-2005, 04:59 PM
