Hey all,
My old ladys VP is playing up.............it wouldnt start but there would be power to the dash and every thing else, she thought it was the Batt, so she went and brought a new one........... but still same thing is happeing, and im trying to find out what it could be?
This is what my mum told me what its doing........ my car has had a new battery put in it but this mornin it just died on it ass but i had lights and all, but would not go till i turned it all off and then it was fine but it still plays up when i put key in the ignition and it sets off the aalrm
Could it be the Computer with a fault?
A loose earth?
Starter on its way out?
Immobiliser?
or something else? plz help
also would a VN Auto calais Computer work in a VP Auto Exec??
Cheers VNCPTR
ecu between vn-vp is interchangeable.
Does the starter click when turning the key?. try bashing it with a pipe, seems to get them going until a replacement is on the way.
nar it dosent make a tick sound, there is nothing......... u turn it a few times and then it will work, but i was thinkin it could be the alarm............?
aftermarket alarm?? if its being set off, theres a voltage drop in the system. its most likely your alternator brush's/voltage regulator.
you may of had lights on the dash but they would of been dim?
im not sure if its after market as it was in it when she brought it 1 1/2 years ago, but ill try that mate and ill see if its that if not then ill look at other possibilities......
if thats not the problem, i have another list of things for you to check out. if it's not a calais/statesman/ etc chances are its aftermarket.
yer i think it is, but yer that list would be great m8, thanx for your help ay
