will a vn calais dash/ cluster fit straight into vp berlina without mods. not worried if odometer works or not mainly just the speedo tacho and other gauges.
alan
short answer no....not without a bit of mucking around
Long answer yes.
VN/P are interchangeable.
As long as both clusters are out of V6s (or both out of V8s etc)
Originally Posted by davway
Without the odometer and as long as its out of the same engine car (V6 or V8) Yes it will.
You may have to move 1 or 2 wires for the different lights depending how old the VN Cluster is.
Just remember No odometer isnt legal and plus you dont get all the cool Gadgets that come with fitting a Calais Dash.
The odometer should still work as per normal.
thanks guys. probaly just put dash in for now and get the other bits done later.
Stealthy odometer wont as it requires the 4th connector to receive reading. Vp1 there is quite a bit involved in installing one into a vp so that everything works. I suggest you read the sticky at the top of this section. If most of that goes way over your head i can do the switchblock mods needed. I also have the full conversion out of mine for sale
Oh my bad, i assumed he already had a Level 3 dash, and was just getting a new cluster.
Thats right, all 4 gauges will work, none of the trips at the bottom will (hence no odometer)
put dash in today all gauges worked but had a high pitched whistle. put stock dash back in whistle gone .any idea"s
you need to switch around a couple of wires in the 3 plugs ont he back. read Converting to a VN Calais dash for more info
1995 Manual HSV Clubsport
1991 Supercharged VN Berlina
yes connector number 1 check engine and press remote need to be changed. To get the wires out remove connector from its position het that stupid orange thing offremove yellow tags use a skewer or the like and push into where the tangs or whatever are you'll get the idea
