Results 1 to 7 of 7
Thread: are these worth getting and will they fit??
    VN SS 5.0
    Aug 2007
    Wagon_Wheel's Avatar
    Wagon_Wheel is offline Drop A Patch....
    Aug 2005
    Mt Martha, Vic
    Yes they will fit.
    Are you putting a cam in along with those?
    If not, there is absolutely no point.
    Wont be a noticeable gain with a cam either...
    Blown V6 Hatch's Avatar
    Blown V6 Hatch is offline Too many projects.....
    VN Calais 5.0, UC Torana hatch 383, WB Ute 5.0
    Jun 2005
    Cowes, Phillip Island
    VN SS 5.0
    Aug 2007
    what if the engine is old and in need of a refresh? also will be supercharged soon.
    Aug 2005
    Mt Martha, Vic
    There is no point doing push rods or valve springs on a stock, non cammed motor, unless they are actually damaged.
    They will do nothing performance wise.
    Also, roller rockers dont do a great deal with the 5ltrs, like they do on the V6's, because there is only ratio's of 1.6 and 1.65 i think, which is just on stock ratio anyway.
    Where as the V6 ones have may different options for different purposes.
    If your looking to freshen up your motor, maybe get a VRS set and chuck that in and clean it all up, and maybe take the heads in to get freshened up too
    VP Executive R-spec
    Jan 2005
    You might as well get the springs in, if you feel like doing something they aren't much different than the stock springs pressure wise but usually makes them a little crisper up high if the old ones have been around the block a few million times. Forget the rockers tho, waste of time
    Jun 2005
    Agreed with Greenfoam, if you are rebuilding the engine then by all means wack a new set of valve springs in.....
  1. How much do you think this is worth?
    By Thomas1 in forum The Pub
    Last Post: 22-04-2007, 07:07 PM
  2. How much is this amp worth
    By G4orce in forum Car Audio
    Last Post: 17-11-2006, 08:14 AM
  3. what are they worth?
    By Troy711 in forum VZ Holden Commodore (2004 - 2006)
    Last Post: 08-01-2006, 06:51 PM
  4. $$how much is it worth
    By Tom04 in forum VR - VS Holden Commodore (1993 - 1997)
    Last Post: 30-12-2005, 09:48 PM
  5. My 92 VP worth it?
    By sparra_gump in forum VN - VP Holden Commodore (1988 - 1993)
    Last Post: 08-11-2005, 08:08 PM
