Results 1 to 8 of 8
Thread: LPG Problem, Won't Idle
    HoZy's Avatar
    HoZy is offline //There Ain't No Rest For The Wicked...
    BMW E39 540i
    Jul 2004
    S/E Subs, Melb
    Default LPG Problem, Won't Idle
    Hey all...
    Trying to get gas running again so i can in term put my gas research system on.. But I've replaced my converter with a new LG A1 replacement Impco one & i've even replaced my Impco mixer an still no luck..
    If i have car running on petrol at about 2000rpm then switch to gas gas will run but it will not idle at all... It won't start on gas aswell...
    Taken it to LPGAS1 & some other gas joint & neither could find the issue..
    Any ideas?!?!?!?
    MaT
    Quote Originally Posted by garth
    well if it isnt mr i only have temp bans. how long you intending on staying this time hozy.
    vn wagon
    Sep 2007
    aldgate sa
    havent got a vaccum leak somewhere have you. is the solnoid opening at the tank end. just a couple of thought as ive had these problems myself in the past
    HoZy's Avatar
    BMW E39 540i
    Jul 2004
    S/E Subs, Melb
    No vacuum leaks, Last thing I'm thinking is the tank, so next lil bit of mulah i got i'll get the tank checked & all valves changed..
    MaT
    azz
    azz is offline azz
    vp wagon
    May 2008
    maryborough
    check the hose between the converter and the mixer i had a tiny crack in the spiral wound pipe and it was doing exactly what your car was doing.
    HoZy's Avatar
    BMW E39 540i
    Jul 2004
    S/E Subs, Melb
    Ok, well that spiral wound pipe, got it replaced, tanks valves an everything is ok... also did an error code test on ecu, code12 no problems.. This is really doin my head in.. An theres no gas leaks.
    MaT
    EDIT:
    Wondering if it has anything to do with the tune I have.. I don't know but I'm starting to think it...
    azz
    azz is offline azz
    vp wagon
    May 2008
    maryborough
    is it running well on fuel, and im not sure how you would check on a commodore but is the inlet mannifold leaking, gas realies on vacume and idleing is the hardest thing for it to do, did it backfire because that can **** the diaphram in the mixer, and is the gas mixture too lean cause that causes simular problems, gas is great when it works but crap when its wrong good luck
    vn wagon
    Sep 2007
    aldgate sa
    another thing . my original computer has a gas chip fitted. i had computer problems so swapped it with the spare one i had in the shed. started the car on petrol ran like a dream changed over to gas and it ran like a p.o;s. would not idle or run for that matter, it just coughed and spluttered. so changed the chip to original gas one and everything worked. mechanic said the original should have read the gas as another fuel and adjusted itself, but it didn't.
    so whether this is your problem ????????.
    georgeonboost's Avatar
    georgeonboost is offline clutch it!
    slammed VP EXEC
    Jun 2005
    Melb SE Suburbs
    i had the hose from the power valve to the mixer come off on me last night and my car stalled...it wouldnt start on gas at all...just fired up and stalled. reconnected the pipe and runs again.
    the gas systems have a safety feature for example when the hose came off the power valve last night it somehow senses it and shuts the gas system off; no gas getting pumped through.
    my 2c, hope it helps
    -George
  1. VN V6 idle problem
    By Webster_140db in forum VN - VP Holden Commodore (1988 - 1993)
    Last Post: 07-05-2006, 11:04 PM
  2. Vn Idle Problem
    By Doolang in forum VN - VP Holden Commodore (1988 - 1993)
    Last Post: 22-08-2005, 12:14 AM
  3. Idle problem
    By LYRIC in forum VT - VX Holden Commodore (1997 - 2002)
    Last Post: 27-07-2005, 04:24 PM
  4. Vn Idle Problem
    By keatz_RedVN in forum VN - VP Holden Commodore (1988 - 1993)
    Last Post: 30-04-2004, 06:25 PM
  5. Vn V6 Idle Problem
    By jackus in forum VN - VP Holden Commodore (1988 - 1993)
    Last Post: 13-11-2003, 07:12 AM
