i got a vn v6 3800 block and recently replaced the dfi and the coil pack. what i need to know is what the correct firing order is and what leads go to which spark plug from the dfi! what is the cylinder numbers when u look at the front of the block? is number 1 the front left or whatever?
the v6 firing order is 165432, cant remember the configuration of leads.. havent owned a v6 for a while.
and for whoever gives the diagram, let them know if its a s1 or s2 coil pack.
pretty sure that cylinders on passenger side from radiator or front to back are 1,3,5 drivers side from front to back are 2,4,6 is your coil pack in three parts ie new or one peice old
