Results 1 to 13 of 13
Thread: ecotec converstion into vp
    vp ecotec c6
    Jun 2008
    Default ecotec converstion into vp
    hey guys just a question i have been told i can put the ecotec out of a vx into my vp with no probes but i will have to use a vn-vp auto and two wires on the injector wires need to be longer and that's pretty much it what else do i ahve to do and is this information i got false please someone help need to get this ecotec in asap
    HoZy's Avatar
    HoZy is offline //There Ain't No Rest For The Wicked...
    BMW E39 540i
    Jul 2004
    S/E Subs, Melb
    I dunno if the info is false man.. Running an ecotec in a VN/VP is like hopes an dreams.. If ur a crazy **** anythings possible hahahahahaha
    Nah its as simple as hell man..
    You needa tap the MAT sensor from the buick6's manifold into the intake plenum of the ecote, lengthen the IAC wiring, lengthen some injector wiring, tap an plumb the WTS into the wat water neck aswell.. You also need to use a vn/vp knock sensor & oil pressure switch.. also a vn/vp oxy sensor...
    MaT
    P.S- Need any help just ask..
    Quote Originally Posted by garth
    well if it isnt mr i only have temp bans. how long you intending on staying this time hozy.
    VN S1
    Jan 2008
    HoZy's Avatar
    BMW E39 540i
    Jul 2004
    S/E Subs, Melb
    Nah! Really? I'll be doing it again soonish too...
    vp ecotec c6
    Jun 2008
    ok whats the mat sensor and where is it lol and also what is the iac wiring lol
    vp ecotec c6
    Jun 2008
    so there wont be any mods needed to to fit the motor in and can i use the wiring and ecu out of my vp
    vp ecotec c6
    Jun 2008
    VP Executive R-spec
    Jan 2005
    Quote Originally Posted by shanecullen69 View Post
    No mods, yes you use the VP wires and ecu like Hozy said ^ and no you wont need the bcm
    vp ecotec c6
    Jun 2008
    vp ecotec c6
    Jun 2008
    sorry i just wanna be sure before i get it in that i have every bit og bad and good info
    HoZy's Avatar
    BMW E39 540i
    Jul 2004
    S/E Subs, Melb
    sorry to do this.. BUT THERE IS A ****ING SEARCH FUNCTION FOR A REASON!
    there are numerous threads about this an also about my conversion that i did which has mooooooooore than enough information
    vp ecotec c6
    Jun 2008
    i have searched im stuck i have got the engine almost in then the mounts wouldnt go in i give up some guy just gave me a supercharged vp motor so ill put that in so ill have the ecotec and auto for sale
    VPCalais38's Avatar
    VPCalais38 is offline VP Sleeper
    93 VP V6 Calais Series II
    Nov 2005
    Geraldton, W.A
    Make sure you set your profile to show all threads and not just ones from like the last two months. I noticed I couldnt find bugger all in a search til I did this.
LinkBacks (?)
  1. Fluctuating idle on deceleration in 3.8 V6 auto (ECOTEC and non-ECOTEC)
    By cliffo78 in forum VY Holden Commodore (2002 - 2004)
    Last Post: 25-04-2009, 12:02 AM
  2. question about manual converstion
    By bendez in forum VR - VS Holden Commodore (1993 - 1997)
    Last Post: 16-10-2007, 07:15 PM
  3. ecotec in a vk
    By commo69 in forum VB - VK Holden Commodore (1978 - 1985)
    Last Post: 12-03-2007, 05:42 AM
  4. VN-VS Dash converstion
    By Ute God in forum VN - VP Holden Commodore (1988 - 1993)
    Last Post: 20-10-2005, 07:53 PM
  5. Ecotec in Vp
    By G4orce in forum VR - VS Holden Commodore (1993 - 1997)
    Last Post: 04-08-2005, 12:27 AM
