Results 1 to 6 of 6
Thread: conrod and main bearings
    VN SS 5.0
    Aug 2007
    Default conrod and main bearings
    i was just wondering how i would go about replacing my conrod bearings and main bearings.
    would it be possible just by removing the oil sump and doing it from underneath?
    VP Exec
    Jun 2005
    Assuming the crank is OK, yep but awkward. Conrod bearings are easy, one at a time. With mains, again one at a time, the trick is to use a split pin inserted into (each) oil hole to rotate the block side of the bearings into place using the crank. It's up to you whether or not you check the clearances; Plastigage is the only way that I know of to do that without pulling the crank.
    1989 VN Berlina
    Jul 2008
    Gladstone, Queensland
    Blown V6 Hatch's Avatar
    Blown V6 Hatch is offline Too many projects.....
    VN Calais 5.0, UC Torana hatch 383, WB Ute 5.0
    Jun 2005
    Cowes, Phillip Island
    How does solder tell you what size the clearances are?? Plastigauge comes with measurements on the package so you can compare them and see what size the clearances are.....How do you do that with solder?? If you cant get plastigauge, you shouldn't be building an engine!
    Pub247's Avatar
    Pub247 is offline Donating Member
    92 VP wagon Daily
    Apr 2006
    Melbourne S.E.
    Quote Originally Posted by 89berlina View Post
    Some soldar instead of Plastigage also does the trick.
    LOL just read this thread how'd i miss it. Love to know where you can get solder that is 1 thou thick would be great for this nano computer i'm building.
    Also if you can fit solder in your clearances then i suggest you stay away from engines
    vs commodore V6 S2
    Nov 2006
    maryborough QLD
    Quote Originally Posted by Pub24/7 View Post
    yeh before it blows up jks
  1. VS Wheel Bearings & Axle Bearings
    By Harvs82 in forum VR - VS Holden Commodore (1993 - 1997)
    Last Post: 25-09-2006, 07:41 PM
  2. bearings
    By ab56452001 in forum VN - VP Holden Commodore (1988 - 1993)
    Last Post: 24-09-2006, 10:17 PM
  3. Help needed snapped a conrod
    By SPAIN in forum VT - VX Holden Commodore (1997 - 2002)
    Last Post: 04-07-2006, 01:05 PM
  4. wheel bearings
    By flyen in forum General
    Last Post: 01-06-2006, 11:58 PM
  5. VP Wheel Bearings.
    By RAMJET in forum VN - VP Holden Commodore (1988 - 1993)
    Last Post: 18-07-2005, 03:18 PM
