Results 1 to 12 of 12
Thread: Remove VP Steering Wheel
    01' VX SS Manual
    Apr 2008
    Default Remove VP Steering Wheel
    Hi guys,
    I've done a search for this but had no luck. I'm trying to get the steering wheel off my VP Calais and getting nowhere. I've undone the big bolt in the middle and tried pulling the wheel off by hand and i've tried bashing it off from behind with a big hammer but no luck .
    Anyone here have any good tips for me I'm getting so damn frustrated with this thing . lol
    Cheers guys,
    Glen
    adam69 is offline Banned
    VT Clubby
    Oct 2004
    Put the bolt halfway back on so it doesnt hit your face and keep bashing.Work your way around.It will come.
    mischa's Avatar
    mischa is offline <- 245rwkw Holden V8
    VN V6 T5 - 355 VN GRP A REP T56
    Jun 2005
    Ashbury, NSW
    GET A STEERING WHEEL PULLER!!!
    Trust me its cheaper then letting ur dad smash it with a hammer
    But really the puller is the way to go, its well worth it.
    Quote Originally Posted by keza87 View Post
    Really who wouldn't want to give Jack a good smack in the back of the head.
    The Daily VN T5V6
    355 VN GRP A REP
    vn wagon
    Sep 2007
    aldgate sa
    as the guys have said put nut on first, then what i have done is hit the rim of the wheel in line with nut using the heel of the hands giving it a few good hits, then grab the wheel a riggle it fairly hard. it should come loose . thats how i got my steering wheel off
    STEALTHY™'s Avatar
    STEALTHY™ is offline So Wet For You!
    VP Calais International, VP Berlina LX Wagon
    Jan 2005
    SA - The Roadworks State
    DON'T hit the steering wheel at all.
    Put the nut back on as said, then start pulling and pushing (you have to be pretty forceful to get it to work)
    If the wheel has never been off the car before, it will take a while, my VL took about 15 minutes of pushing/pulling trying to lever it off
    Quote Originally Posted by davway
    Improved Suspension Reduces Handling!
    Quote Originally Posted by JONNNNOOOOO!!
    cheers sexy
    01' VX SS Manual
    Apr 2008
    See the funny thing is, I actually had it off about 3 months ago because I had to straighten it up! And it came off really easily by hand. Could it be something else causing my wheel to go off centre ? It's turned about 90deg to the left but does not seem to go any further than that.
    Cheers,
    Glen
    STEALTHY™'s Avatar
    Jan 2005
    Just read its for your calais.
    Chances are you've snapped your diff cradle. reverse the car up your driveway, and see if one of the rear wheels has ALOT of camber.
    cheers sexy
    VP Berlina LX wagon 5.0L M5
    Dec 2005
    as was already stated.. the best way to get it off is to loosen the nut to near the end of the thread (making sure its still on the thread so that when the wheel comes off, the nut will stop it smashing you in the face)... and then holding the steering wheel at both sides, wiggle it really hard. for example, pull with your left hand, while pushing with your right, then vise versa really quick and hard. sort of like you're boxing-left,right,left,right really quickly.
    hope that makes some sense.
    sometimes they are really hard to get off, so you've gotta be pretty violent. with enough force it should come off. failing that, a steering wheel puller.
    - James
    STEALTHY™'s Avatar
    Jan 2005
    If it is his cradle like i suspect, theres no need to remove the steering wheel now.
    cheers sexy
    01' VX SS Manual
    Apr 2008
    Just finished checking out the camber and had a look at the cradle and all seems fine, camber looks all normal and no cracks in the cradle. Maybe it's worn bushes or steering rack ?
    STEALTHY™'s Avatar
    Jan 2005
    Could just be you've hit a gutter and the wheel alignment is out, but the cradle issue is hard to spot, and is only visible when the car has been reversed, if it was last driven forwards, you wont see anything different.
    cheers sexy
    VT Clubby
    Oct 2004
    Quote Originally Posted by Glen_P View Post
    Do you have a camber kit in the rear?If you do it may be out.Had that prob with my VQ.
LinkBacks (?)
  1. How To Remove Steering Wheel And Gear Shifter
    By Troy711 in forum VR - VS Holden Commodore (1993 - 1997)
    Last Post: 02-09-2010, 06:36 PM
  2. remove steering wheel ??
    By ozfreerider1 in forum VR - VS Holden Commodore (1993 - 1997)
    Last Post: 16-05-2008, 12:38 AM
  3. Remove steering wheel controls (airbag safety)
    By glassjowned in forum VT - VX Holden Commodore (1997 - 2002)
    Last Post: 08-06-2006, 07:39 AM
  4. remove steering wheel?
    By kooloo in forum VB - VK Holden Commodore (1978 - 1985)
    Last Post: 24-09-2005, 07:34 PM
  5. Replies: 6
    Last Post: 08-07-2005, 07:33 PM
