Results 1 to 10 of 10
Thread: temp and oil pressure guages
    VE SS SPORTSWAGON
    Jan 2006
    Warwick
    Default temp and oil pressure guages
    i bought a type r temp guage for my project car, i wanna know does the ecu need the old sender or can i simply remove the old one and replace it with the new one?
    same deal with the oil pressure guage. im just thinkn of getting a t piece connection for that one.
    vn calais, vs clubsport #137
    Jun 2005
    unless you want a check engine light on constantly. yes you will need the stock ones in )
    LowVp's Avatar
    LowVp is offline VP nut
    VP Ute 3.8T M5
    Aug 2005
    Ipswich, Qld
    there are 2 senders for the temp, 1 for the ecu the other for the gauge on the dash.
    and yeah just buy a T piece for the oil pressure
    VE SS SPORTSWAGON
    Jan 2006
    Warwick
    Quote Originally Posted by LowVp View Post
    dont know where id find these 2?
    cheers,
    Blown V6 Hatch's Avatar
    Blown V6 Hatch is offline Too many projects.....
    VN Calais 5.0, UC Torana hatch 383, WB Ute 5.0
    Jun 2005
    Cowes, Phillip Island
    immortality's Avatar
    VN3.8 5spd/VSII3.8/VH5.0
    Apr 2006
    Auckland NZ
    as above, which engine. as a rule of thumb however, the temp sensors are generally close to the thermostat housing as this is the warmest point on the engine before the coolant goes to the radiator
    Body by Holden, Soul by Brock
    the Legend will live forever
    VN_Luke's Avatar
    VN_Luke is offline ƃuoɹʍ ʇsnɾ sı sıɥʇ
    VT, RB30EST VN
    Mar 2005
    and the ECU needs to know the temperature of the coolant in order to be able to fuel and control spark accordingly.....
    plus the v6 uses the temp to control the thermo fan as well.
    You can get an adapter that goes into your top rad hose with a fitting for a sender, this way the factory bits and pieces remain unmolested.
    VS 355 Turbo, VN Calais 5L, VE SII SV6 Wag, Mirage
    Aug 2006
    Adelaide, SA
    You'll need a T piece for the oil pressure. the temp sensor u can remove the factory temp sensor and put the one in for the temp gauge. you just won't get the light on the dash.
    VN-VS have 2x temp sensors one for the ECU and one for the dash gauge. just make sure u remove the one for the dash gauge. its the one with a single green wire going to it. the sensor with the injector like plug on it is for the ECU.
    KiwiHoldenDriver is offline Loud, proud Kiwi
    VT Olympic Spec V6
    Jan 2008
    Auckland, New Zealand
    Quote Originally Posted by VN_Luke View Post
    Useful info. My fan stopped working recently and my fuel consumption seems to have jumped up at the same time. I jumped the fan relay to earth so it runs all the time but now that I know the problem I will get it sorted.
    is it better to get for a new one?
    VT Olympic Spec V6
    Jan 2008
    Never mind. Found out a new sensor is $28 including Governmental Screwthepublic Tax
  1. oil temp and pressure guages?
    By pen15 in forum VR - VS Holden Commodore (1993 - 1997)
    Last Post: 21-01-2008, 10:20 PM
  2. Installing Oil Pressure and Volt Guages.....Anyone know how ?????
    By kilmo in forum VZ Holden Commodore (2004 - 2006)
    Last Post: 05-02-2007, 09:26 PM
  3. fuel pressure guages
    By bigg_vin in forum VB - VK Holden Commodore (1978 - 1985)
    Last Post: 29-08-2006, 09:01 AM
  4. Sticky Fuel & Temp Guages
    By Harvs82 in forum VR - VS Holden Commodore (1993 - 1997)
    Last Post: 26-01-2006, 09:27 AM
  5. aftermarket temp guages
    By dagsy in forum VT - VX Holden Commodore (1997 - 2002)
    Last Post: 19-08-2004, 11:10 AM
