Page 1 of 2 12 LastLast
Results 1 to 25 of 26
Thread: 12 second car
    savage1987's Avatar
    savage1987 is offline fail champion
    LS1 VN + 304 VN
    Blackjack Champion!
    May 2005
    Default 12 second car
    So...... just felt like asking, what does a VN need in order to end up with a 12 second street car? I'm considering an LS1 manual for mine and I couldn't help wondering.
    Sam
    WTB: mulberry VN interior parts
    vnv8driver is offline Banned
    304 Calais
    Aug 2007
    Up your mum
    VN_Luke's Avatar
    VN_Luke is offline ƃuoɹʍ ʇsnɾ sı sıɥʇ
    VT, RB30EST VN
    Mar 2005
    Quote Originally Posted by vnv8driver View Post
    v6 turbo @ 20psi
    v8 s/c @10psi
    ls1 with mafless tune, exhaust
    on the v6 note, I think SC's v6 vegetable did 12's on 10-11psi? (YouTube - V6 Vengeance 2) but regardless, the options are pretty much right i reckon.
    - boosted 6, (not much more easy potential) - not epa friendly
    - heavily worked 5 litre N/A (not much more easy potential) - not epa friendly
    - boosted 5 litre (fair bit of potential) - not epa friendly
    - or a bolt on ls1 (heaps of potential) - epa friendly... until you start using up that new potential
    Also keep in mind costs of not just the motor, but making sure the gearbox/trans can handle the power, cost of a stall converter, diff, tuning etc...as it all adds up to more than the cost of building/transplanting a motor
    89 VN Exec, 94 VR SS
    Dec 2007
    I think cost is the biggest issue not how its done, seems as tho the cheapest and best would prolly be the v6 turbo or the ls1 route.
    Jun 2005
    ^^ ls1 would be the most expensive route
    1995 Manual HSV Clubsport
    1991 Supercharged VN Berlina
    AirStrike's Avatar
    AirStrike is offline Site Administrator
    2009 G6ET
    Jun 2003
    Quote Originally Posted by 89 vn View Post
    HAHAHAHA!!! V6 turbo would be the hardest way and a LS1 would be the most expensive.
    Selling FG G6E Turbo and buying a N/A Supra
    Jun 2005
    agreed there. turbo is a fair bit of work unless you know what youre doing, and expensive if youre getting someone else to do it.
    my sc14 setup would probably run a 13, and possibly a 12 if i did a bit more work on the engine, gearbox and diff. would probably cost you 2-3k to do it right.
    ls1 youll need about 10k.
    just get a 5 litre and work on that if youre only after a 12 second car.
    STEALTHY™'s Avatar
    STEALTHY™ is offline So Wet For You!
    VP Calais International, VP Berlina LX Wagon
    Jan 2005
    SA - The Roadworks State
    Get yourself that 12 with a manual (with any of those motor combo's)
    Quote Originally Posted by davway
    Improved Suspension Reduces Handling!
    Quote Originally Posted by JONNNNOOOOO!!
    cheers sexy
    304 Calais
    Aug 2007
    Up your mum
    if his cars already a v6 a sc14 kit with injectors, pumps, tune on top of an engine/transmission rebuild, lowering the compression in the motor a bit, he should be able to make a reliable 12 second car for just under 10 grand.
    Jun 2005
    should be able to do the above for under 3
    VN_Luke's Avatar
    VT, RB30EST VN
    Mar 2005
    I reckon if you know what you're doing, and can do most of the work yourself, you could turbo the v6 and get it to run an 11 for the "around $10k" mark
    (starting with a stock v6 auto - presuming the engine is a-ok)
    - 3000 for an eBay turbo kit with all the piping, oil lines etc you need
    - 1000 sell the eBay crap turbo and buy a 2nd hand 35/40 or so
    - 800 3" exhaust made up with dump pipe (including towing costs etc)
    - 200 minispool diff, including oils, gasket etc
    - 500 good injectors and a 2 bar MAP sensor
    - 2000 get the auto strengthened to suit
    - 500 2nd hand stall converer to suit
    - 800 tune
    - 200 tyres
    - 1000 random bits and pieces, oils, clips, clamps, pipes, fittings, sealant, nuts and bolts and the odd tool or two
    so that's 10k there - could probably spend a bit more/less depending on what you can do yourself or not etc..
    but of course, as they say - you take the guesstimate and you double it, then you get close to how much it'll actually cost lol
    VS 355 Turbo, VN Calais 5L, VE SII SV6 Wag, Mirage
    Aug 2006
    Adelaide, SA
    I wouldnt bother with any SC14 supercharger kit for a V6 if u want to go fast. they are **** any only for people wanting a small boost from a V6.
    Reaper's Avatar
    Reaper is offline Tells it like it is.
    E3 Senator Manual, VP SS
    Aug 2004
    I would think a "not to wild" 5 litre would get 12's quite easily in a VN. Depending on how handy you are the biggest issue would be the inlet manifold.
    My shopping list would be.
    TTB manifold
    10 - 10.5:1 compression
    Mild head work & valves
    Roller rockers
    Cam (hydraulic should still be ok)
    zorst
    tune.
    Reaper
    Reapers Black VP SS
    0-60 mph = 5.39 Sec, 2.30 60'
    Quote Originally Posted by skruba View Post
    practice makes perfect dude i was (still am) my bros guinea pig,he has been tattooing for near 2 years.
    Aug 2006
    Adelaide, SA
    Its alright having an engine that can run 12's but you need a driveline and traction that can do 12s as well. thats not cheap...
  15. #15
    savage1987's Avatar
    LS1 VN + 304 VN
    Blackjack Champion!
    May 2005
  16. #16
    Dec 2007
    Yeah the LS route would be the most expensive i guess in a way:
    LS2 6.2 litre $4850
    MM6 L98 6 speed $2750 =7k for the parts
    Can the LS2 fit into a VN like the way an LS1 does? ifso that seems like a potent setup especially if u can use an LS2 motor, they give 270kw isnt it?
    oh and they LS's have ****loads of potential since that is stock? yeah if i could choose i would choose that
  17. #17
    savage1987's Avatar
    LS1 VN + 304 VN
    Blackjack Champion!
    May 2005
    Cheaper than that mate, I'm not looking for a crate motor, a second-hand one will do me fine. LS1 with manual six speed, do the majority of the work myself... shouldn't be anywhere near your typical drive in drive out price.
  18. #18
    VP Executive R-spec
    Jan 2005
    I'm agreeing with reaper, if you know what you're about the right cam and manifold will go a high 12 on the 5 litre in a manual and the manual will take it for a while/long time depending on your luck too that will be the best cheap semi legal way to get there. Turbo V6 also cheap if you know what you are doing, vengence went 11.8 and could have been done alot cheaper than it was, a healthy used motor will take 12 psi no problem but more troubles with the laws.
    If you have the cash the ls1 is the only sensible way to go and with limited mods will go 11's and more legal than any other option, also a boosted 5 litre (turbo) will go 11's on mildish amounts of boost but totally un epa friendly.
    There's also the RB30 option which could be done much more cheaply and somewhat less realiably than Luke has done it but you could go 12's on a scrap yard RB30 and chinese turbo no problem if you wanted to
    If I was going to do this and had 5 grand I go in the order of
    5 litre, diy..... or super budget RB30 conversion
    A 286 type cam, home ported heads and home made or improved manifold has done high 12 in a manual 5 litre plenty times before, typically 12.8 <
    If I had 10 grand I'd go
    LS1
    Bit less budget RB30 conversion
  19. #19
    Boonz's Avatar
    Boonz is offline the holden mechanic
    green 355 VG ute , silver vx s pac L67
    Jul 2005
    berri, south australia
    you can build a tuff 355 for under 10 grand still
    just gotta be spot on with the cam and stall converter choice if you go auto to go 12's cos you dont want it to be unstreetable if you go with a massive cam
    traction is still the killer in a VN with solid rear end trust me and anyone with a bit of power going to the ground with a solid rear and stock wheel arches
  20. #20
    savage1987's Avatar
    LS1 VN + 304 VN
    Blackjack Champion!
    May 2005
    If an LS1 goes near the VN it'll be either:
    a) getting some serious rear tyres and a VL Turbo rear end to fit more serious rear tyres ;
    or b) not a VN any more and my VP Calais master plan has worked!!
    Sam
  21. #21
    Jun 2006
    Western Aus.
    Quote Originally Posted by Peanuts Inc. View Post
    How streetable it is will come down to the tune. Couple of mad 355's running over here (One in a VP doing 10.7's the other a VB running 10.9's both around 500hp). Both are driven on the street on weekends.
    Hot Lap Motorsport
  22. #22
    VX SS II 6.3L/M6
    May 2005
    Well ill be the dick who says...
    If you want a fast car, just buy a fast car. Honestly i hate saying it (as i would love to drop a LS2 into my VR wagon) but you can get a VX SS Gen3 Manual with low kays for like $16k these days. You can probably get your hands on a Gen3 Manual VT for like $12k...
    Then your starting with a good base to handle big power... Theres no stuffing around or unexpected costs and its going to be easier to insure, register etc.
    Otherwise, get your hands on a wrecked VZ SS and drop an LS2 in
  23. #23
    304 Calais
    Aug 2007
    Up your mum
    my mate was look at a wh statesman with 89000 on the clock, ls1 autp, leather, vgc, 14 grand with rwc.
  24. #24
    PaRaDoX's Avatar
    PaRaDoX is offline boosted!
    Forester GT, VT S Supercharged, Supra Turbo
    Apr 2005
    Melbourne, Victoria
    Quote Originally Posted by VN_Luke View Post
    snap in rb30!
  25. #25
    VNV6VENGEANCE's Avatar
    VNV6VENGEANCE is offline VeNgeance
    VN Turbo
    Jan 2006
    adelaide,sa
    Quote Originally Posted by feistl View Post
    gen 3 manual vt is heavy, he wants a gen 3 in a lighter model. Hence giving him a better chance of getting to 12's. Personally im biased but go the turbo route. Everyone has v8's an turbo v6's raise a few eyebrows. plus petty aint cheap
    only good cops a dead cop...
    s1 vn commodore turbo
    t3/t4 front mounted turbo
    Intercooler ---3"exhaust
    stage 2 shift kit---B&M Qicksilver shifter
    3:45 lsd
    18" Cv8z Monaro rims 245's
