Results 1 to 5 of 5
Thread: 92 Toyota Lexcen (VP Commy) Steering Rack
    TVR-190's Avatar
    TVR-190 is offline SkyFall
    WK Statesman LS1
    Jun 2008
    Sutherland Shire N.S.W
    Default 92 Toyota Lexcen (VP Commy) Steering Rack
    Went for rego today but the car didnt pass because the steering rack is leaking, the guy said he could replace it for $600.
    Do you think it sounds fair or would i be able to do a patch job on it?
    The Black Beauty
    Morton's Avatar
    Fairstar the Funship
    May 2006
    Depends how bad the leak is. They usually condemn something as "leaking" if there's oil on it.
    1) if your pwr steering resivoir is low enough to allow, add a bottle of stop-leak.
    2) drive around for half an hour, leave overnight.
    3) get under there and degrease it PROPERLY. clean EVERYTHING until it's spotless.
    4) go for a drive with some nice corners. Do some 3-pointers.
    5) park it, get under, have a look.
    6) if the leak is bad enough that it's beading up to drip after a short drive,
    a) see if it's coming from a hose (if it is, try tightening it or changing the hose)
    b) if it's coming from the body of the rack, get it changed somewhere cheaper
    7) if it ISN'T leaking visibly after your spirited drive and turning maneuvours, then just remember to degrease it again before your next rwc
    edit: I remember a small fact that a RWC inspector once shared with me in Victoria. If you can thoroughly clean the underside of a car, drive it around the block, park it, get it up on the hoist, and not have any obvious leaks or beads of oil forming straight away, it can technically pass. This is how he passed my VP with a rear main leak. After a short drive, the outside of the main seal was moist with oil, but it wasn't wet to the point where it was forming a "run". That was a pass, and so no further work was needed.
    The 1972 HQ Kingswood
    Blown V6 Hatch's Avatar
    Blown V6 Hatch is offline Too many projects.....
    VN Calais 5.0, UC Torana hatch 383, WB Ute 5.0
    Jun 2005
    Cowes, Phillip Island
    As for the price being fair, depends on whether he is fitting a reco or second hand rack....
    Reco= fair price
    Second hand= Ripping you a new one
    VP Executive R-spec
    Jan 2005
    I bought a reco rack of some guys on ebay that rebuild them, no change over and it was only like $250 it's a pretty simple job to bolt one in (loc tite everything)
    TVR-190's Avatar
    WK Statesman LS1
    Jun 2008
    Well instead of replacing the whole thing my step dad had a look and cleaned it up, tightened a few screws and now its fine.
    The Black Beauty
  1. 92 Toyota Lexcen (VP Commy)
    By TVR-190 in forum VN - VP - VG - VQ
    Last Post: 27-06-2008, 11:45 AM
  2. 1990 Toyota Lexcen Vn Gl (mel)
    By gbug in forum Parts And Other Items For Sale
    Last Post: 25-01-2007, 12:00 AM
  3. toyota lexcen
    By State'O ReBeL in forum Parts And Other Items For Sale
    Last Post: 10-04-2006, 10:06 AM
  4. is a toyota lexcen engine better than a vp
    By stackner in forum VN - VP Holden Commodore (1988 - 1993)
    Last Post: 14-11-2005, 08:22 PM
  5. Looking for part for Toyota Lexcen
    By U2Bono in forum Swap / Wanted to Buy / Trade
    Last Post: 30-08-2005, 11:13 AM
