Results 1 to 25 of 25
Thread: torque converter screwed?
    Jun 2005
    Default torque converter screwed?
    Im having a weird problem with my gearbox. When im travelling between 80-100km/h, when the torque converter would normally lock up, it tries to do this a few times, but just makes weird grinding noises and fails. Eventually it will lock up, but it still feels weird. Also, when im going 80km/h, in the low end of 4th gear, the car vibrates pretty badly. All i can think of it being is a problem with the torque converter. Does this sound right?
    1995 Manual HSV Clubsport
    1991 Supercharged VN Berlina
    Pub247's Avatar
    Pub247 is offline Donating Member
    92 VP wagon Daily
    Apr 2006
    Melbourne S.E.
    I'd say its torque convertor related but there are other things that might be worth looking at too. Does it make a whining sort of noise when not locked but goes away when locked? not locking up could be the solenoid. vibration is a hard one could be numerous things like uni's gb mount unbalanced driveshaft centre bearing.
    Jun 2005
    well there is a whining noise at 80-100 km/h, but that comes from the back of the car and im fairly certain its the diff
    vnv8driver is offline Banned
    304 Calais
    Aug 2007
    Up your mum
    common problem with the vn torque converters, if your not running a cooler im not surprised it isnt stuffed... could also be centre bearing or trans mount though.
    when on the highway and your off the accelerator at 100, then put your foot down is nthere a little delay then the revs drop and the cat akes off??
    Jun 2005
    it does run a cooler. ill see if theres a delay when i drive it later tonight. would an auto service help at all? or will i need a new converter?
    Jun 2005
    and theres another weird noise. in 1st and 2nd gear, above 2500rpm or so, there as odd noise i cant describe. when it changes gear, it almost sounds like a very quiet blow off valve.
    304 Calais
    Aug 2007
    Up your mum
    trans service wont fix it waste of time and money, is the noise while the transmission is trying to change gears or just accelerating?
    Jun 2005
    just accelerating. and the noise i think is diff whine only seems to exist at anything above 0% throttle. when i dont have my foot on the pedal, you cant really notice it. it sounds like its coming from the diff, but i dunno if its a tranny noise that is resonating to the back of the car maybe
    PaRaDoX's Avatar
    PaRaDoX is offline boosted!
    Forester GT, VT S Supercharged, Supra Turbo
    Apr 2005
    Melbourne, Victoria
    304 Calais
    Aug 2007
    Up your mum
    ive never heard the trans making a blowoff moise before im lost there, if you loeave the lever in third gear and lightly accelerate up hils/under load does it make the grinding/vibration? if so previous experience tells me it is the converter.
    Steery's Avatar
    Steery is offline AA 554 G
    94 VR SS M5
    Feb 2008
    Adelaide, near Cross Road Maccas.
    my car has the delay thing when going back onto the throttle, that means the converter is on its way out yeah?
    304 Calais
    Aug 2007
    Up your mum
    chances are, the heat of the th700's without a cooler literally warps the converter.
    vs commodore V6 S2
    Nov 2006
    maryborough QLD
    Quote Originally Posted by vnv8driver View Post
    but they all do have a cooler from factory...not saying its teh best though but there is one there haha :P:
    '92 HSV VP GTS
    Apr 2005
    SE Queensland
  15. #15
    Jun 2005
    wheres the hose? i know SFA about transmissions
  16. #16
    88GreenVN's Avatar
    88 Green VN Wagon 389,000kms
    Jun 2006
    Deep South - VN Country
    Quote Originally Posted by stocky View Post
    The grinding noise is bad bits going round in the tranny. The wagon made this noise for a few days, then the vibrations started. Then dead tranny. The mechanic said it was rubbish in the clutches from lack of a service (maybe a few years without a service).
    Time for a replacement transmission.
    and 3 Dangerous non ABS VN's
  17. #17
    Jun 2005
    did yours only do it around 90km and above? it only does it when its locking the converter. the rest of the time it feels fine. no other problems
  18. #18
    88GreenVN's Avatar
    Jun 2006
    Started when on the expressway @ 100kph. Then more often at lower speeds - when the converter locks up at around 60kph
  19. #19
    Jun 2005
    hmm might have to look for a manual box. anyone know if i need the manual flywheel too? or is there anyway i can fix my current auto?
  20. #20
    88GreenVN's Avatar
    Jun 2006
    When I went from the 5 speed to the auto I had to change the motor & trans as the crank end is different.
    My car was a S1 so thats probably why.
  21. #21
    azkwazere is offline Ahhh Yes, Ahhh Yes....
    VP 5-SPD / 24-SPD Racer Hybrid
    May 2005
    .....SE Burbs
  22. #22
    Jun 2005
    its series 2
  23. #23
    304 Calais
    Aug 2007
    Up your mum
  24. #24
    May 2005
    .....SE Burbs
    have a looksie at the vr manual conversion thread that just popped up...
    i can swap ya the guards for a pedal box if ya want.
    aZk.
  25. #25
    Jun 2005
    i cant tell what the problem is. it doesnt seem bad now, only a slight vibration around 90km/h. seemed to be worse when i had passengers in the back. bought some new oil i might change it over the weekend
  1. VR V6 Torque Converter
    By Sara Pax in forum VR - VS Holden Commodore (1993 - 1997)
    Last Post: 08-03-2008, 01:20 PM
  2. torque converter
    By kniever in forum VN - VP Holden Commodore (1988 - 1993)
    Last Post: 04-03-2008, 03:26 PM
  3. torque converter
    By Dayvo in forum VT - VX Holden Commodore (1997 - 2002)
    Last Post: 25-04-2006, 10:53 PM
  4. Torque converter?
    By spauldj308 in forum VR - VS Holden Commodore (1993 - 1997)
    Last Post: 09-02-2006, 07:02 PM
  5. Torque converter on VS
    By Gleno in forum General
    Last Post: 31-05-2005, 01:13 AM
