Page 1 of 3 123 LastLast
Results 1 to 25 of 58
Thread: Extra power from Modified Genuine GM CAI
    97 VS Acclaim
    Aug 2006
    Sydney, NSW
    Default Extra power from Modified Genuine GM CAI
    Hey folks... not too sure if anyone has done this but I did this this afternoon, been running a VS Supercharged CAI and now have modified my CAI intake to almost 3 times the amount of air going into the engine. Here are the pictures of my modification. All you need is an angle grinder, file off the rough edges or use a sandpaper for smooth finishing. I felt that the gear changes are better and take off is MUCH better. If anyone can load a stock unmodified CAI so you can compare the difference in airflow. Also not too sure if doing this is legal of not...!!!
    Attached Thumbnails Attached Thumbnails Extra power from Modified Genuine GM CAI-dsc01934.jpg   Extra power from Modified Genuine GM CAI-dsc01935.jpg   Extra power from Modified Genuine GM CAI-dsc01939.jpg   Extra power from Modified Genuine GM CAI-dsc01941.jpg   Extra power from Modified Genuine GM CAI-dsc01945.jpg
    '92 HSV VP GTS
    Apr 2005
    SE Queensland
    Quote Originally Posted by ThongyVL View Post
    Yeah, there are a few different modifications you can do to these, not all include hacking them. Of course its not illegal lol.
    car
    Jul 2006
    greensy, melb
    i also cut mine back as the opening was way too small from factory and i just wasnt satisfied. after cutting mine back the differance to me was ten fold and it felt alot more responsive so im happy with it now.
    it wont let me post up the pics again so if ya wanna see them look at my ride thread
    "A life lived in fear is a life half lived"
    89 VN Exec, 94 VR SS
    Dec 2007
    I believe greenfoam did it aaaaages ago and posted pics, he used a heat gun and a block of wood wedge in the mouth, yeah no offence but I dont think opening your cai a bit more would give you much of a difference. on my VN i was running a front bar pipe and i added another pipe which sat a bit higher and i felt absolutely no difference. Just get a KN panel filter to make sure your getting the most out of it and remember tho the coolest air is at the lower/lowest point of your car
    VNV6VENGEANCE's Avatar
    VNV6VENGEANCE is offline VeNgeance
    VN Turbo
    Jan 2006
    adelaide,sa
    yeh i had thought of doing this but my idea was a bit different. If you look at the difference between the vs and vt sc cai the vt though being smaller has an angled inlet. (the top plastic is further back towards the engine than the bottom). Now this might just be to compensate for the bonnet closing issues a few people had with the originals but my bet is it increases the airflow. 89 vn has got it right no matter what you do to it you won't feel a major difference if any at all.
    only good cops a dead cop...
    s1 vn commodore turbo
    t3/t4 front mounted turbo
    Intercooler ---3"exhaust
    stage 2 shift kit---B&M Qicksilver shifter
    3:45 lsd
    18" Cv8z Monaro rims 245's
    Morton's Avatar
    Fairstar the Funship
    May 2006
    I've never been a HUGE fan of the OTR CAIs, but I can see what you've done there probably reduces response time a tiny little bit. I'm personally a fan of the box-to-front-bumper style CAI, where airflow isn't restricted by the bonnet rubbers, and is nice and cold
    The 1972 HQ Kingswood
    car
    Jul 2006
    greensy, melb
    the gain wasnt major but it was noticeable to and just felt like it revved a little bit easier
    and i took the rubber off that was right in front of the cai to let as much air as possible cos the size of the standard opening on the v8 ones is just rediculous, they really are a tiny opening and i cant see how it would do anything lol
    Black VN MANUAL
    Feb 2007
    Top of Vic
    I have a VS S/C CAI and cut it back, not heaps only took it back 2cm where the lines on the CAI start and it opened up up more 1/3 more proberbly, and i also took the rubbers off the bonnet, i was going to try and make a shelid type of thing from the Letterbox grill up to the CAI so the air is going thro the letterbox grill and into it so more cold air gets in there, insted of being restricted by the VN bonnets, i was also thinking of running another pipe somewhere to the bumper as Morton has done and have both style CAIs.
    ~ VN POWER ~ Click the scales
    Morton's Avatar
    May 2006
    VP Executive R-spec
    Jan 2005
    PaRaDoX's Avatar
    PaRaDoX is offline boosted!
    Forester GT, VT S Supercharged, Supra Turbo
    Apr 2005
    Melbourne, Victoria
    97 VS Acclaim
    Aug 2006
    Sydney, NSW
    Morton might win... But I see the ripples in the pipe causes restriction. Unless the bottom of the intake has a much greater volume than the ones in the pictures of the CAI cut out. Cold air is one thing, the other thing is how much volume of air flow you get into the engine is another.
    Aug 2004
    VP Executive R-spec
    Jan 2005
    The airflow through a rippled pipe 110mm is so much more than a 65mm throttle can breath it wont matter to Morton, air temp is all that's important, you can't make much positive pressure through any pipe, just enough to take away the restriction of the filter is about all you can ask
  15. #15
    Morton's Avatar
    May 2006
    Yeah, what greenfoam said It's 110mm, the largest I could get my greasy hands on, so it shouldn't cause restriction.
    The reason I specifically chose ribbed pipe, (aside from the ease of installation), over creating my own smooth piped creation, was that the ribs in the pipe prevent water ascending, and catch 90% of the stones, flies, moths, rocks, leaves, and other debris that want to enter the airbox and clog up the filter.
    When I take out the CAI every few months for a shakedown, you wouldn't believe how much crap falls out
    I should really upload new pics of mine on the stato though. The silly looking cable tie is gone, and there's some light aluminium fly-screen mesh infront of it, to 1) hide it, and 2) prevent quite so many rocks, leaves and moths getting in there as did on my VP :P
  16. #16
    vnv8driver is offline Banned
    304 Calais
    Aug 2007
    Up your mum
    stock gm cai is crap tacular, hides behind the grille/bonnet and doesnt allow for a good amount of air to be forced into the collector, a setup like paradox's, mine or mortons forces alot more cool air to the filter, costs less and looks just about factory.
  17. #17
    Dec 2007
    Since ive ran front bar CAI inside my airbox ive found some stuff, small rocks, insects and some small leaves and a tiny ammount of sand. None of it made its way past the filter so it just stays in the box till you clean it out. Like Morton says the ribbed pipe is good but mine was even lower so it sucked more crap but it still was ok. Hate to see it w/o a filter tho..
  18. #18
    Morton's Avatar
    May 2006
    hahaha, it's brilliant isn't it The amount of crap that manages to find its way up there. I'm actually amazed that small stones can find their way around the corners and up the pipe. I've had a few small ones, and I just can't picture them bouncing all the way up "by chance", because god knows there isn't enough suction in an induction system to drag them up
  19. #19
    Not_An_Abba_Fan's Avatar
    HSV Senator VTII
    Aug 2006
    Bunbury, WA
    A CAI doesn't actually gain power. All it does is increase responsiveness.
    Oh, and the engine doesn't suck anything in. The low pressure caused by the piston moving down in it's stroke causes the higher surrounding atmospheric pressure to push air in.
    Visit my Facebook page
  20. #20
    Chirpstr's Avatar
    Chirpstr is offline A new project attack
    VR Berlina M5, VP M5
    Sep 2007
    I cut mine to two small rings after seeing Abba fan with his one some time ago. The only thing, I tried to cut it on there and did a butcher job lol. Used soldering iron, hacksaw, allsorts lol. It's actually pretty thick stuff. I wasn't satisfied with how it was either I must say and still not although I did noticed a increase in air noise and suction after doing it. My gauge never goes over the quarter mark on temp gauge when crusieing...I think it would just hit the quarter mark when I first put the CAI on...so it does seem to breath better. Not sure about power increase though......
    I might cut it like ThongyVL to neaten it up a bit so I won't have to hit myself every time I open the bonnet lol.
  21. #21
    Morton's Avatar
    May 2006
    Quote Originally Posted by Not_An_Abba_Fan View Post
    I was under the impression that colder air is denser, contains more oxygen per cubic foot, and (in lay mans terms) makes the petrol boom better, which generates more power A CAI by definition has nothing to do with responsiveness, unless it's a ram-style CAI like on the LS2, which attempts to create positive pressure in the system. Even a bumper-ram system like mine has too many curves in it to generate significant positive pressure.
    And I believe that's what we call suction. Therefore, the engine sucks air in.
    "Suction is the flow of a fluid into a partial vacuum, or region of low pressure." -wiki
  22. #22
    HSV Senator VTII
    Aug 2006
    Bunbury, WA
    Unfortunately wiki isn't a scientific definition, but we are splitting hairs. Suction is the result of a vacuum, fluid dynamics and the way they move in atmosphere is the result if pressure differential. High pressure pushes fluid to low pressure, low pressure doesn't suck.
    Yes, by definition a CAI should produce a colder more condensed charge, and by doing so it makes a more complete combustion resulting in better response, not more power. You are only putting as much air in as the engine can cope with. Forcing it in is an entirely different kettle of fish.
  23. #23
    Morton's Avatar
    May 2006
    But splitting hairs is such fun ^___^
    If creating low pressure in order to draw something in, is not suction, then what is? Say I were to use a straw to pick a crumb of chocolate off the table. I place the straw near the crumb, breathe in, and the crumb follows the flow of air through the straw, and into my mouth. Where I eat it. Could it not be said that I sucked it up? Or would we have to be technical and say that I created an area of low pressure in my lungs by moving my diaphragm and ribs outward, causing the high pressure around the crumb to move up the straw, dragging the crumb with it?
    I think it would be acceptable to say I sucked it up ^__^
    "more complete combustion" = more fuel being properly ignited = bigger boom = more power?
    I thought it was a commonly accepted fact that cars will give a better dyno readout on cold days?
  24. #24
    immortality's Avatar
    VN3.8 5spd/VSII3.8/VH5.0
    Apr 2006
    Auckland NZ
    go get a large medical syringe, put your finger over the hole and pull the plunger down (just like a piston going down in the bore) it seems like suction to me.
    CIA does improve power. cooler denser air contains more O2 so the PCM injects more fuel to maintain correct fuel to air ratios, that means more power. yes a engine will only suck as much air as it requires, however if oyu can increase the density and therefor the O2 content it's got to make more power
    Body by Holden, Soul by Brock
    the Legend will live forever
  25. #25
    Morton's Avatar
    May 2006
    Quote Originally Posted by immortality View Post
    Thanks immortality ^__^ I was starting to think I as losing my marbles
  1. extra power?
    By Torquen in forum VR - VS Holden Commodore (1993 - 1997)
    Last Post: 31-03-2006, 01:07 PM
  2. My Modified VS SS
    By klorz in forum VR - VS
    Last Post: 23-01-2006, 12:59 PM
  3. Anyone got a modified V8 on LPG ? Even a Gen III?
    By muso in forum VT - VX Holden Commodore (1997 - 2002)
    Last Post: 19-11-2005, 06:36 PM
  4. Most modified CV8 you'll see???
    By Lexx in forum General Discussion
    Last Post: 31-08-2005, 12:23 AM
  5. My Vl - About To Modified
    By vl_lightening in forum VL Holden Commodore (1986 - 1988)
    Last Post: 11-05-2004, 08:30 PM
