Results 1 to 7 of 7
Thread: vn calais dash
    vn v6 calais
    May 2008
    Unhappy vn calais dash
    i have just bought a vn calais,
    was curious to what type of dash they should have,
    this one has tacho, speedo, temperature and fuel, plus trip meter etc etc?
    i thought they would have had oil pressure and volts as well?
    also on a different note the petrol and temp gauge aren't working, the heater blows out cold air as well,
    any help with some answers be much apreciated
    cheers
    '92 HSV VP GTS
    Apr 2005
    SE Queensland
    Quote Originally Posted by creamy View Post
    cheers
    No they dont have Oil pressure, but you can get a battery voltage readout if you have your car turned off and hold Mode and Reset buttons then turn the key to accessories. Then press Mode to scroll the different readouts.
    Have you tried bashing the top of the cluster with your hand to see of the guages work, you can fix it by soldering some connections on the back of the cluster board but I forgot which ones that you solder.
    vn v6 calais
    May 2008
    yeah there is a threrad on here 'bout soldering some connections here, but bit to technical for me,, no good with a soldering iron,
    cheers,
    i will try bashing the top of dash to see if gauges work
    '92 HSV VP GTS
    Apr 2005
    SE Queensland
    cheers,
    Its not hard man, its like 2 little blobs of solder, saves you smashing the crap outa your car too
    vn v6 calais
    May 2008
    just tried banging the dash to get gauges to work, wal ah, they work
    i might try the soldering tonight
    cheers
    Feb 2008
    Feb 2008
    yea solder the connection better. no prper contact so the needles not getting any power to put it up. when you bash it, then it makes connection. good luck with that anyway
  1. vp calais dash loom into vn calais
    By calais_8 in forum Electrical Wiring / Questions
    Last Post: 17-07-2008, 12:57 AM
  2. vn calais dash
    By vr-man in forum VN - VP Holden Commodore (1988 - 1993)
    Last Post: 21-06-2008, 08:34 PM
  3. VK Calais dash into VH
    By bacon-n-eggs in forum VB - VK Holden Commodore (1978 - 1985)
    Last Post: 21-09-2006, 11:28 PM
  4. vp how to change dash to calais dash
    By hoon1 in forum VN - VP Holden Commodore (1988 - 1993)
    Last Post: 06-09-2006, 07:35 PM
