Results 1 to 12 of 12
Thread: replacing inner tie rod ends on a vp
    vp
    Nov 2007
    Default replacing inner tie rod ends on a vp
    Hi all
    How are the tie rod balls attached to the rack ends?
    Do they just bolt on or are they swaged?
    Can it be done without removing the rack under the car in shed with trolley jack/stands or do I need special tools?
    Many thanks
    Rileyp
    VN Wagon
    Feb 2005
    The tie rod ball joints are screwed onto the rack ends. There is a locking nut (22mm) as well. They are attach to the hub with a tapered pin, nut and split pin.
    They can be changed using a jack, stand (think safety) spanners and a big hammer or ball joint splitter thingie.
    You might want to change your steering rack boots at the same time if they are getting old.
    PaRaDoX's Avatar
    PaRaDoX is offline boosted!
    Forester GT, VT S Supercharged, Supra Turbo
    Apr 2005
    Melbourne, Victoria
    vnv8driver is offline Banned
    304 Calais
    Aug 2007
    Up your mum
    inner tierods, you mean inner steering arm? if so unbolt the tierod end and it will simply pull out if its stuffed... liquid nails will get you around for a few months with no dramas until you het another replacement item and wheel alignment.
    vp
    Nov 2007
    Quote Originally Posted by vnv8driver View Post
    I mean the tie rods complete with inner ball and socket underneath the rack boots.
    Not the outer ones on the tapered pin that you hit with a hammer to jar and pop out then simply spin off once loosened with 22mm spanner/pipe wrench.
    the question more specifically is how are the inner tie rod ends ball sockets attached to the steering rack.
    here a pic of some replacement ones on ebay....
    Holden Commodore VL VN VP Rack Ends,Boots & Tie Rod End - eBay, Other Car Parts, Accessories, Car Parts, Accessories, Cars, Bikes, Boats. (end time 11-Jul-08 11:37:13 AEST)
    vp
    Nov 2007
    liquid nails on what? the tie rod end?
    this doesn't sound very safe.........
    Not_An_Abba_Fan's Avatar
    HSV Senator VTII
    Aug 2006
    Bunbury, WA
    The socket end is just screwed into the rack. A pipe wrench or large spanner will undo them. No need to remove the rack. You can do them with the tie rod ends still attached to the steering arm, but it is a lot easier if you separate them as well.
    Visit my Facebook page
    vp
    Nov 2007
    Quote Originally Posted by Not_An_Abba_Fan View Post
    thankyou for your fast response....
    time to go buy some....
    cheers rileyp
    VP Exec
    Jun 2005
    Quote Originally Posted by rileyp View Post
    vnV8driver is taking the ****...
    Adding to what TurboXS (Pete), PaRaDoX616 and Not_An_Abba_Fan have posted, there will be locking washers sandwiched between the tie rod (inner ends) and the ends of the steering rack. These are folded over onto flats on the tie rod (inner ends) and have tabs that engage in the end of the rack, thus the locking function.
    With the rack boot off, the folded over parts can be knocked back with a pin punch and hammer before unscrewing the ends.
    Ideally the lock washers should be replaced each time but may be reused if the flats end up in a different place with the new tie rods. Swapping them side to side sometimes helps. I hope it's obvious that they have to be folded back over to lock the new tie rods in place.
    Counting the number of turns you have to unscrew the tie rods out of the outer tie rod ends, and matching that when you screw the new ones in, will allow you to get the wheel alignment close enough to drive get a W/A done professionally without damage to the tyres.
    vp
    Nov 2007
    I pulled off a boot this arvo had a good look and saw the lock washers
    and figured I'd have to knock them flat and I understand the necessity of locking them once the new rods are installed.
    Thanks everyone for your help
    cheers rileyp
    VN Wagon
    Feb 2005
    Oddly enough when I saw this post I had just finished replacing the steering rack boot. I did wonder which end of the tie rod you were refering to.
    I also had seen the kit you mentioned and I'm amazed at how cheap it is considering buying the steering boot alone was $10 for me.
    vp
    Nov 2007
  1. VR/VS Outer tie rod ends
    By gslrallysport in forum Parts And Other Items For Sale
    Last Post: 28-02-2008, 08:43 PM
  2. tie rod ends
    By DANNY8 in forum VB - VK Holden Commodore (1978 - 1985)
    Last Post: 03-02-2007, 09:28 AM
  3. Tie Rod ends? Problem
    By VHSLX3300 in forum VN - VP Holden Commodore (1988 - 1993)
    Last Post: 13-01-2007, 04:26 PM
  4. Marketing 101 - Does anyone know how this ends?
    By BlackVXGTS in forum Jokes/Humour
    Last Post: 22-08-2006, 01:36 PM
  5. it just never ends
    By impakt in forum VN - VP Holden Commodore (1988 - 1993)
    Last Post: 13-03-2006, 10:23 PM
