Results 1 to 4 of 4
Thread: replacing ignition switch ???
    vn v6 calais
    May 2008
    Lightbulb replacing ignition switch ???
    is this a hard thing to do?
    any give me a few details on how to do this plz?
    vp v6 commodore executive
    Aug 2006
    south island newzealand
    do you want to change the tumbler for the key or the actual electrical contacts part if you want to change tumbler put key in turn key away from park position push the pin in the little hole around outside of ignition barrel and it should pull out
    vnv8driver is offline Banned
    304 Calais
    Aug 2007
    Up your mum
    if your changing the igntion pigtail, undo the little screw at the end of the barrel and undo the plug, it simply pulls off then and can have the replacement put on.
    vn v6 calais
    May 2008
    cheers, thanks
  1. Replacing Ignition Asembly on a VL
    By Diazepam in forum VL Holden Commodore (1986 - 1988)
    Last Post: 17-04-2007, 10:03 PM
  2. ignition switch
    By h0Ld3n`VN in forum VN - VP Holden Commodore (1988 - 1993)
    Last Post: 26-07-2006, 11:23 PM
  3. replacing ignition module on a VK
    By VKNutt in forum VB - VK Holden Commodore (1978 - 1985)
    Last Post: 19-07-2006, 11:51 AM
  4. HELP! VK Ignition Switch
    By CommodoreChick in forum VB - VK Holden Commodore (1978 - 1985)
    Last Post: 10-11-2005, 07:10 PM
  5. vs ignition switch problem
    By markovr in forum VR - VS Holden Commodore (1993 - 1997)
    Last Post: 26-06-2005, 01:26 PM
