Results 1 to 4 of 4
Thread: Car cutting out in gear, need quick advice
    HSV +6
    Mar 2006
    Mornington Peninsula
    Default Car cutting out in gear, need quick advice
    Basically ill put the car into reverse and idle out of my driveway, ill stop, put it into drive and go off. Lately while ive been reversing sometimes if cuts out. The electrics stay on, but power steering goes and the engine shuts off.
    Checked all the liquids (engine oil, P.S, etc etc) and everything seems to be at the right level.
    My steering wheel has felt "loose", in the best way i can describe it, but unsure if thats connected to the problem.
    Any suggestions on what it could be? Or what i should check to narrow things down?
    vnv8driver is offline Banned
    304 Calais
    Aug 2007
    Up your mum
    take the intake piping off the throttle body and give the idle control motor a blast with carby cleaner.
    Tom_1569's Avatar
    Tom_1569 is offline Ecotech Power
    VS Ute - Daily, VT - Spare, 80 Series - W/E Bus
    Nov 2006
    Gippsland - VIC
    TPS - Thorttle position sensor.
    That the reason ours does it.
    Quote Originally Posted by alien View Post
    I have been hit by oil badly once while in Army uniform on a massive roundabout that doesn't exist anymore. Spun 180 degrees to face oncoming traffic.
    HSV +6
    Mar 2006
    Took it to the mechanic, said water is getting in when its cold causing it to run so bad til it warms up. Unfortunately im tired and forgotten where its getting in, he said water is getting under the gasket.
    I have the car back for the weekend, got told to take it back in Monday to recheck how its going. Im guessing it cant be too serious then if i have the car back for the weekend.
  1. Need Recommendation and Advice on Gear!
    By Heffer_Slayer in forum Car Audio
    Last Post: 25-11-2007, 11:38 PM
  2. Engine cutting out on gear upshift (auto)
    By red131 in forum VY Holden Commodore (2002 - 2004)
    Last Post: 27-09-2006, 11:43 AM
  3. Quick Question - VK running gear into a VS
    By sir409 in forum VR - VS Holden Commodore (1993 - 1997)
    Last Post: 28-05-2006, 05:32 PM
  4. Advice - botched key cutting - stuffed ignition
    By vh-holden in forum General
    Last Post: 20-12-2005, 09:18 PM
  5. Need Quick Advice!!!asap
    By Commodore_Chick in forum VR - VS Holden Commodore (1993 - 1997)
    Last Post: 30-08-2005, 11:35 PM
