Results 1 to 9 of 9
Thread: Steering wheels
    VP exec ser2 wagon
    Aug 2005
    Default Steering wheels
    Hi, can anybody tell me if vp vr vs etc steering wheels are interchangable? I have just put (I thought) a VP column into my VP wagon but, the original steering wheel doesn't fit. It doesn't go on far enough for the horn ring to mate up with the sprung contact so I have no horn. Has any one else had this problem? Thanks.
    Pub247's Avatar
    Pub247 is offline Donating Member
    92 VP wagon Daily
    Apr 2006
    Melbourne S.E.
    Ok vr/vs wheels are different. I I cant rember exactly but i heard something similar to your problem with interchanging wheels. It may be that you have a vr/vs column instead of a vp. Where'd did you get it from? might be worth trying a vr wheel on there.
    VP exec ser2 wagon
    Aug 2005
    I thought VR/VS column was adjustable height so assumed it was VP.Came out of smashed VP wagon that had split rear seat and dicky seat fitted.The rest looked standard. Will try to get hold of VR wheel to try.
    Dumped IRS VS Acclaim 3.8, VR Stato Caprice 5.0
    Nov 2007
    Hatton Vale. country at its best. :)
    hey stockhorse... i had a vr steering wheel [from my brothers vr] and it fitted with no problems, it held on the vp column as the vp wheel would...
    the problem u have is that u bought urslef a vr steering column not a vp...
    the vp had a solid rear seat [wagon and sedan], whereas the vr had the split rear seat [wagon]..
    so u need to have a vr/vs [non vs airbag wheel]for it to fit properly..
    does that help u out a fair bit..
    VP exec ser2 wagon
    Aug 2005
    VP calais, VJ valiant, BG5 legacy
    Jan 2008
    New Plymouth, New Zealand
    crazyspoon05's Avatar
    crazyspoon05 is offline Penguin Whisperer
    The 'Bizta' VNVPVR Wagz
    May 2006
    I've got the airbag looking wheel on my VN and apart from the small gap between the wheel and the column cover but fitted fine and indicators still cancel so all good
    If ignorance is bliss why aren't there more happy people around ?
    Nov 2007
    Quote Originally Posted by Andrew426 View Post
    So, I take it that a VN/VP steering wheel will not fit my VR?
    nah mate. the vp wheel will not fit a vr column...
    VP Berlina LX wagon 5.0L M5
    Dec 2005
    i had a VR steering wheel on my VP. there is a gap between the plastic around the column and the wheel, but horn, indicator cancel all worked fine.
    is it possible to put an adjustable (height and reach) VR/VS steering column on a VN/VP?
    -James
  1. Boss kits for VT steering wheels to fit a VZ/VY steering wheel?
    By nEb. in forum VT - VX Holden Commodore (1997 - 2002)
    Last Post: 27-12-2011, 07:28 PM
  2. steering wheels??
    By roger05 in forum VN - VP Holden Commodore (1988 - 1993)
    Last Post: 22-06-2010, 11:11 PM
  3. Do VT/X Steering wheels fit VR/S ??
    By NORTI in forum VR - VS Holden Commodore (1993 - 1997)
    Last Post: 16-04-2008, 08:58 PM
  4. Steering Wheels
    By QNLOOK in forum VN - VP Holden Commodore (1988 - 1993)
    Last Post: 28-12-2006, 03:22 PM
  5. different width wheels and flat bottom steering wheels?
    By Troy711 in forum VE Holden Commodore (2006 - ?)
    Last Post: 24-09-2006, 05:50 PM
