Results 1 to 15 of 15
Thread: Diff backlash problem?
    VN Executive
    Apr 2007
    Wellington, New Zealand
    Default Diff backlash problem?
    Hi
    the Diff in my VN exec has excessive play, by that i mean if i accelerate then decelerate then accelerate i hear a "bonk" kind of noise coming from the rear.
    will replacing the diff center fix this or will i have to get the entire diff reset?
    also will my diff blow if i keep driving it like this? i only drive on the motorway really and dont do much start stop stuff.
    Thanks
    '92 HSV VP GTS
    Apr 2005
    SE Queensland
    VN_Luke's Avatar
    VN_Luke is offline ƃuoɹʍ ʇsnɾ sı sıɥʇ
    VT, RB30EST VN
    Mar 2005
    as mack said, it could be uni joints
    could also be caused by center bearing on the tail shaft.
    apparently small noises from those parts can be significantly amplified and make it sound like a much bigger movement.
    however if you chuck your car in neutral, get under there and move the tailshaft with your hands, and it's CLEARLY got lots of play in it (i.e. the diff yoke/flange turns/wiggles as well) then you have excessive backlash (possibly amongst the other problems too).
    It won't "blow up" as such, but you will be wearing your gears excessively and making them significantly more prone to failure. The issue could be that the gears just need to be re-aligned - a diff guy should do it for about 100 bux. Failing that, you might have excessively worn gears that don't mesh nicely, in which case you could buy new gears and get them fitted up, or just buy a whole new diff for 50 bux and fit it up in a few hours
    let us know how you go!
    VN Executive
    Apr 2007
    cheers for the help, i had it on a hoist a while ago but i think it was in park. there was some play, ill have a look this weekend.
    by gears do you mean gearbox or diff gears?
    '92 HSV VP GTS
    Apr 2005
    SE Queensland
    Quote Originally Posted by Anthraxnz View Post
    He means Diff.
    VN_Luke's Avatar
    VT, RB30EST VN
    Mar 2005
    VN Calais 5L
    Dec 2006
    VN Executive
    Apr 2007
    vnv8driver is offline Banned
    304 Calais
    Aug 2007
    Up your mum
    perfectly normal mate, by the sounds of the video you need uni joints.. also have a bash on the centre bearing, if theres play it will need replacing also.
    when you drop it into gear from neutral/oark do you hear a clunk? also is there any vibration?
    VN Executive
    Apr 2007
    yeah i do hear a clunk every time. sometimes its loud sometimes its not so loud, depends on what the revs are doing.
    Pub247's Avatar
    Pub247 is offline Donating Member
    92 VP wagon Daily
    Apr 2006
    Melbourne S.E.
    uni joints imo, replace them first its pretty compared to what a diff costs
    VP Executive 5 Speed
    Jan 2009
    Erskine Park
    I've got the same sound from my diff. However my box is manual. Been like this for a few months now. In a few weeks we are chucking a LSD in it
    Also, cause my box is manual and the diff came from an auto, what will need to be changed?
    My Commodore - http://forums.justcommodores.com.au/...executive.html
    V6. Cat Back Exhaust. 18" Rims. Homemade CAI. Lowered to the max. Sound System. Klaxton Air Horn - "Ahooooooogah"
    VP PARTS F/S ENGINE/BOX
    2007 VE SS
    Nov 2006
    ey fellas,
    ive got a VN Calais 5.0L auto.
    i have kinda the same problem. the only thing different i have is that when im driving along at a constant speed sometimes i hear fast knocking coming from the rear. when its under load (going up a hill or accelerating) its fine. when i put it in any gear apart from neutral, it clunks something cronic. also backing off the accelerator it clunks and when reapplied it clunks. i havent got a hoist so i cant really check it out myself. im close to buying a new diff centre and paying someone to chuck it in. should i do this or look into it further first ?
    calais_cruzin's Avatar
    calais_cruzin is offline Calais_Rattling....
    92 VP Calais 3.8
    May 2006
    Gold Coast
    Quote Originally Posted by Turtle57 View Post
    Its the same eh man nothing will need to be changed over, the only diffferece between auto n manuals was the front half of the tailshaft.
    vkhg, do what the OP did n move ur tailshaft see if that has the excess play in the uni's or center bearing, b4 lashing out on a diff
    ________________________________________
  15. #15
    2007 VE SS
    Nov 2006
    fixed my problem.
    i was told that if my uni joints were shagged that it would vibrate the whole car and i wasnt experiencing anything like that. so i went out on a limb and bought an lsd diff from ebay for $300 (immaculate condition) and put it in the car. when i took the old one out i found that one of teeth on one of the spider gears was broken so that explains the slop. so with the new lsd in the car problem fixed. twin peggin now too
LinkBacks (?)
  1. 12-07-2008, 05:09 PM
  1. Vn Driveline Backlash
    By jules in forum VN - VP Holden Commodore (1988 - 1993)
    Last Post: 12-01-2009, 05:32 PM
  2. diff backlash?
    By aza64 in forum VT - VX Holden Commodore (1997 - 2002)
    Last Post: 02-10-2007, 10:24 PM
  3. backlash
    By n1tr0us in forum VR - VS Holden Commodore (1993 - 1997)
    Last Post: 19-09-2006, 09:43 PM
  4. diff backlash
    By commy92 in forum VN - VP Holden Commodore (1988 - 1993)
    Last Post: 25-07-2006, 09:22 AM
  5. Diff Problem??
    By sick commy wog in forum VN - VP Holden Commodore (1988 - 1993)
    Last Post: 12-10-2005, 11:54 AM
