Hey guys,
im part the way through building myself up somethin different and was just wondering...
Who has built a buick v6 turbo in Australia, or more WA? Im just tring to figure out wat has been done and wat hasnt because im trying to make my baby stand out from the crowd. Im pretty sure it will when its done, but who
has already done it and to what extent is the work they have done on it
ie
fuel system
trans
turb set up in general?
any details on what has been heard of would make mt day
cheers
Stevo
Stevo it's been done a million times but not many run very well. The success rate tends to run exactly equal to the intelligence of the owner doing the install.
Big injectors (36lb+), big intercooler, and a 2 bar map sensor and 2 bar tune + your general turbo and piping bolted on will make it work how it should. I don't think it's a very wise thing to attempt myself just due to there being better options around
What would be the best option in your opinion for a V6, apart from getting a v8,
FI? i'm tossing up between SC14 SC or doing heads cam work ect and will cost around the same but will get more out of Supercharging
~ VN POWER ~ Click the scales
I always had ideas for the perfect turbo setup... High mount passenger side strut tower, joiner pipe headwrapped alone firewall.. 3" dump exhaust.. cooler with water jet spritser on it... can be done easy but doing it properly thats where the money gets ya!
cheers
MaT
Originally Posted by garth
i realise its not a new thing to do to the v6, im jusg trying to find out what dramas im goin to face along the way, and if i can save myself from a few headaches
i differ from the rest cos my vn is running a dedicated gas set up and i really need the higher compression and dnt wanna go supercharged for the fact its like the town bike on vns here in perth
if you need higher compression, why are you planing a turbo?
power down low isnt really an issue, its getting more air into the poor thing up high so i can make the most from lpg
perhaps a cam.
you can buy the kits from someone (gogle is your friend) or every now and then brand new kits pop up on ebay, getting it enginneered could be a duanting task but it'd be well worth it
selling victorian number plates MADVN6,
pm me if interested
