Results 1 to 10 of 10
Thread: bleeding vn cooling system?
    vn v6 calais
    May 2008
    Unhappy bleeding vn cooling system?
    gunna clean and replace cooling sytem coolant and all the rest of it
    do i need to bleed the system when finished?
    it is a v6 series 1 vn calais
    and how to bleed system please?
    Coast_Calais is offline sick of the idiots here
    varies
    Jul 2008
    gone
    After flushing, refill resiviour to 100%. Run motor, and allow thermostat to begin to open, turn heater on. Then disconnect the heater return hose until continued flow of water appears. Reconnect. Shut down motor, refill coolant.
    That's how i've done it, never had a problem doing so. If there is a proper bleed valve somewhere, someone please tell me...
    (You can do the old inverted coke bottle trick, but it only helps remove gunk, it wont relieve air trapped in heater tap...)
    vn v6 calais
    May 2008
    vn v6 calais
    May 2008
    Question series 1 thermostat
    is it very difficult to change this in the series 1, which appears to be at the rear of the motor,
    any helpful hints or advice or instructions be greatly appreciated
    Pub247's Avatar
    Pub247 is offline Donating Member
    92 VP wagon Daily
    Apr 2006
    Melbourne S.E.
    DanVN's Avatar
    DanVN is offline Cruizin' in style!
    01 WH Statesman International 5.7L
    Nov 2007
    Western Suburbs, Vic
    Pub247's Avatar
    92 VP wagon Daily
    Apr 2006
    Melbourne S.E.
    Yeah should have thought about that you dont need one due to having a pressurised resiviour.
    Not_An_Abba_Fan's Avatar
    HSV Senator VTII
    Aug 2006
    Bunbury, WA
    After flushing, fill it up, idle til warm, top up if required. Drive it for a couple of days, check it again. The VN S1 doesn't really need bleeding as the air will eventually find it's way to the reservoir.
    Visit my Facebook page
    Dumped IRS VS Acclaim 3.8, VR Stato Caprice 5.0
    Nov 2007
    Hatton Vale. country at its best. :)
    Quote Originally Posted by Not_An_Abba_Fan View Post
    well thats good to know. lol
    ive just done the cooling system in my vn today and didnt know where the bleed valve was also.
    so ive just done what u just told us. all done now lol
    rawsonn is offline wants to know more
    VN Berlina
    Aug 2008
    Goonellabah, NSW
    series 1 didnt have a bleed valve but the series 2 i think did
    i love freedom of speach because [ details deleted by moderator]
  1. My Cooling System... Help
    By Explosions Hurt in forum VT - VX Holden Commodore (1997 - 2002)
    Last Post: 30-04-2008, 09:03 PM
  2. cooling system bleeding
    By jatsvl in forum VL Holden Commodore (1986 - 1988)
    Last Post: 05-01-2008, 02:58 PM
  3. Bleeding coolant system
    By coolvxss in forum VT - VX Holden Commodore (1997 - 2002)
    Last Post: 28-12-2006, 05:25 PM
  4. Oil in the cooling system?
    By portercg in forum VR - VS Holden Commodore (1993 - 1997)
    Last Post: 25-12-2004, 11:43 PM
