Results 1 to 4 of 4
Thread: Anti-Theft Wiring Bypass
    vp v6
    Jul 2008
    Default Anti-Theft Wiring Bypass
    Hi, I have a VP V6 that has a part of the anti-theft wiring missing, the connector plug which hangs beside the ALDL plug is vacant and there is definitely nothing there to plug into it. I think this is the cause that is stopping the motor cranking over and stopping the fuel pump from working. There is power at all the relays but nothing is happening when I turn the key. Is it possible to bypass that wiring to get everything? Any help would be appreciated. Cheers Mark
    '76 HJ RB25DET Ute
    Feb 2007
    I dont know what the fault is on your car, but on my VP I can still turn the motor over whilst its immobilised. Just doesn't fire thats all. This info might help you look in another direction. Ie, flat battery haha
    VrWagz1's Avatar
    Vr S2 exec 5.0 man Wagon
    May 2008
    wollongong
    Im pretty sure too that it will let you crank, just wont fire up. I think you have other issues. Can you hear the fuel pump run for a few seconds when you turn the key on.
    Reaper
    vp exec
    Dec 2006
    vaucluse, sydney
    yep with the immobiliser "on" or active, the motor will crank but not fire (sometimes if i have forgotten to disable the immobiliser the engine might will fire once but then stall straight away).
    The immobiliser switch (in the passengers side door cavity) is key-operated with 2 pairs of normally-open contacts. To bypass it, you bridge the 2 pairs of contacts in the loom with 2 insulated wire links.
    From memory, you bridge the orange and orange/black wires in the loom with one wire link, and the other pair of wires in the loom with another link. I have never done it but have had a look at the book to see the theory.
    If you need the details, PM me and i will look in the book.
    The clue to see if the immobiliser is deactivaed (ie will allow the engine to start) is that the orange light on the dash with a little picture of the engine will come on once the immobiliser is deactivated. cheers peter.
  1. anti theft module
    By Matt_vp in forum Electrical Wiring / Questions
    Last Post: 15-04-2007, 08:13 AM
  2. Lpg Anti Theft Module
    By jake_au in forum VT - VX Holden Commodore (1997 - 2002)
    Last Post: 09-09-2006, 08:29 PM
  3. Anti theft (New Alarm)
    By AttaBoy in forum VR - VS Holden Commodore (1993 - 1997)
    Last Post: 15-06-2006, 05:32 PM
  4. Anti-Theft Measures
    By Mr_Slim in forum VN - VP Holden Commodore (1988 - 1993)
    Last Post: 22-08-2005, 10:27 PM
  5. Anti-Theft
    By Lukie in forum VL Holden Commodore (1986 - 1988)
    Last Post: 24-05-2004, 03:45 PM
