Results 1 to 4 of 4
Thread: Warning light and brake problems
    97 VS Esteem
    Mar 2008
    SA
    Default Warning light and brake problems
    hey everyone,
    my parents own a VP i think 1992 or 1993 Berlina. THe car was driving really well until just about 20 minutes ago when my parents came back and said the brakes were not working.
    Description: that red warning light (!) is constantly on and when you put the brake pedal down it goes all the way down really easily and doesnt stop the car that well. ALso i noticed that there is heaps of fluid around the front drivers side wheel and there is fluid missing from the brake filler bottle thingy. WHen i turned the car on and looked at that bottle it seemed to be bubbling like it was leaking.
    I was just wondering if anyone knows what the problem is. i know it has to be a leak but why?
    ANy help is much appreciated
    Gudgeon's Avatar
    Gudgeon is offline NE1 4SX
    VR Exec S2 and VK 333 Pack Calais
    Jul 2008
    Mount Gambier
    sounds like a leak. probably rubbed through on something seeing as it's on the steer and they move. check wot's in reach of the hose. you'll have to bleed up the system again too.. starting furtherest away from the reservoir. thats'd be my guess.
    There's No Replacement For Displacement
    accentstencil's Avatar
    WH II Caprice, 5.7
    Jun 2005
    Eschol Park, Sydney
    Most probably a hole in the brake hose or a stuffed seal on the piston in the caliper. Check the hose for signs of fluid first.
    MY RIDE
    Morton's Avatar
    Fairstar the Funship
    May 2006
    Remove the front right wheel and inspect the caliper.
    1) degrease
    2) dry
    3) reinstall
    4) find source of leak
    5) ??????
    6) PROFIT
    it's probably either a fractured hose or a leak from the bleeder/hose connection. But if the wheel is covered in fluid, and air was getting in, that would cause the bubbles in the reservoir and low fluid level. Could also be a fouled piston seal, requiring overhaul or a new caliper. But I'd be taking the wheel off, cleaning it up, and taking a good look first
    The 1972 HQ Kingswood
  1. VN brake warning light won't go off
    By jc1879 in forum VN - VP Holden Commodore (1988 - 1993)
    Last Post: 15-02-2008, 11:13 AM
  2. 'Rear light bulb failure' warning light
    By Misaprop in forum VT - VX Holden Commodore (1997 - 2002)
    Last Post: 22-04-2006, 03:07 PM
  3. VR Hand brake warning light
    By dean18 in forum VR - VS Holden Commodore (1993 - 1997)
    Last Post: 19-11-2005, 12:42 AM
  4. Brake Warning light comes on
    By Sambo in forum VN - VP Holden Commodore (1988 - 1993)
    Last Post: 24-06-2005, 06:58 PM
  5. Hand Brake warning light
    By tweezy in forum VT - VX Holden Commodore (1997 - 2002)
    Last Post: 01-04-2005, 08:20 PM
