Results 1 to 11 of 11
Thread: Need help with front struts on vp berlina 93
    VP BERLINA 93
    Jul 2008
    Default Need help with front struts on vp berlina 93
    Hey new to forum and I'm having trouble with front struts on my vp berlina 93. I have removed strut assembly from car and compressed springs but I cant undo the top strut bearing nut, It just turns and turns, I can supply some pics if needed of where I'm at on the situation.
    Can anyone help me?
    Dumped IRS VS Acclaim 3.8, VR Stato Caprice 5.0
    Nov 2007
    Hatton Vale. country at its best. :)
    have u got an air-compressor??? its much easier to do it that way??
    or, {i know its bodgy, but it does work bloody well}..u can use a set of vise-grips on the very top of the shock near the bearing plate.
    dont grip it too tight, as u will scar the shock....u need to grip it at the very top under the bumpstop if u can get to it...
    if all else fails, take it to a tyre shop tomorrow, and they should be able to take it apart for ya...
    hope this helps out...
    VP BERLINA 93
    Jul 2008
    Nah no air compressor, should i try to loosen bearing nut a bit before compressing the springs?
    VP BERLINA 93
    Jul 2008
    I cant undo the bearing nut in the center of this pic
    Do I have the compressors on right
    VP BERLINA 93
    Jul 2008
    All good now put new shocks in, all i gotta do is put strut assembly back in. Not a hard job after all, when ya know what to do.
    SweetWagon's Avatar
    SweetWagon is offline booosted
    VS Berlina Wagon Supercharged & VU SS Ute
    Jan 2006
    Springwood NSW
    Quote Originally Posted by CLIFFO_83 View Post
    much easier just to back the nut off when the strut is still on the car
    VP BERLINA 93
    Jul 2008
    VP BERLINA 93
    Jul 2008
    another problem, the lower ball joint bolt keeps turning when i try and tighten the nut. What do I do there?
    1996 VS BT1 SS 5ltr original
    Apr 2008
    jack the car up from the ball joint by doing this you will put the whole preasure from the car on it and you will be able to tighten it up without it spinning.
    VP BERLINA 93
    Jul 2008
    ok, i did that and it worked thanx. Took car for a drive and I can hear knocking do you know what that could be?
    Apr 2008
    pm sent about the nocking noise.
  1. Help with front struts
    By jacksien in forum VN - VP Holden Commodore (1988 - 1993)
    Last Post: 19-07-2008, 07:46 PM
  2. Can someone help me with the Front Struts.
    By VTSSDUDE in forum VT - VX Holden Commodore (1997 - 2002)
    Last Post: 20-03-2007, 12:33 PM
  3. VK to VR front struts
    By immortality in forum VB - VK Holden Commodore (1978 - 1985)
    Last Post: 02-05-2006, 05:50 PM
  4. vn front struts
    By bruised in forum VN - VP Holden Commodore (1988 - 1993)
    Last Post: 08-01-2006, 10:16 AM
  5. VN front struts in a VC
    By Colin Freebairn in forum VB - VK Holden Commodore (1978 - 1985)
    Last Post: 02-08-2005, 02:41 PM
