Results 1 to 8 of 8
Thread: twin exhast for v6 help
    vn executive s2 v6
    Jun 2008
    Default twin exhast for v6 help
    hi im gona be doin a nu exhaust for my v6 and i need opinions.
    i want twin pipes cause i want it to sound as beasty as pos. heres wot iv been dreamin up.
    extractors into twin 2 inch, no cats as its nz spec, two long coby resonaters (one each side) merging into 1 single 2 and half inch pipe just before the diff,out the back im not sure wat type of rear muffler to have fitted? defnaty strat through tho.
    i was thinkin it would be cool to have some type of dump pipe straight after the diff exiting to the side a bit with a removable cap (old hotrod style) 4 the drags.
    wat i need to no is is, is 2 inch the best size for the first section? and 2 and half best for the rear part? i would like it to flo the best it can.
    wher should balance pipes(1 or 2) be fitted? or should i go with a x pipe?
    all opinions would b great as if been searching the net for agis and i dont no if this has been done before on a na v6
    Ozzie's Avatar
    Ozzie is offline JCCC Warrnambool
    Ozzie'z 97 VT
    Jul 2008
    Warrnambool
    from the extractors... 2 1/4" then from the resonators 2 1/2"
    This will not only sound good but would be optimal for performance
    GOTMYN's Avatar
    GOTMYN is offline Stab it and Steer...
    Whippled 5.7, VE SV6, GU Patrol 3.0DI
    Sep 2006
    Mornington, Vic
    Just put a Sports V8 system on it.........Off the shelf, works a treat...Believe me!!
    If I'm not pulling Toyota's out of the Bush, I'm pulling 12's in the Sig :-)
    vn executive s2 v6
    Jun 2008
    is the sport v8 system a twin pipe all the way or just to the diff? how much do these go for?
    GOTMYN's Avatar
    Sep 2006
    Mornington, Vic
    Quote Originally Posted by jonboy View Post
    You can get either, Mine is Twin all then way, with an X Pipe just after the Cat's...Sounds Grouse, and goes very well!!
    About $450 cat Back last time I checked....
    vn calais, vs clubsport #137
    Jun 2005
    if you want twin exhaust, whya re you merging it, why not just keep it twin 2" all the way through, have a decent straight through muffler in each pipe and a cat. and youll have a decent note.
    Not_An_Abba_Fan's Avatar
    HSV Senator VTII
    Aug 2006
    Bunbury, WA
    Quote Originally Posted by VY CHRISSO View Post
    Won't go on a VN though, it's a live axle. It will be difficult to put a twin system all the way through on a live axle car. It can be done but it's not straight forward.
    What you originally wanted is fine, twin 2" off extractors, but I would run them side by side down the same side and into a twin in single out straight through muffler, then 2 1/2" out the back.
    Visit my Facebook page
    vn executive s2 v6
    Jun 2008
    cheers for evyones input, yea the reason i was planin for single out the rear was cause there ant much room between diff an body on the solid axle vns.
    il b lookin into these v8 of the shelf sistems i think an way up the cost o gettin one made up (my dads a mean welder so il just have to buy pipes an mufflers)
    will post pix wen its all done
  1. welding exhast!!
    By jas98 in forum VN - VP Holden Commodore (1988 - 1993)
    Last Post: 14-09-2007, 10:33 AM
  2. s1 and s2 exhast manifold
    By vks in forum VN - VP Holden Commodore (1988 - 1993)
    Last Post: 09-11-2006, 09:58 PM
  3. VT twin fan versus AU twin fans question
    By FXST01 in forum Electrical Wiring / Questions
    Last Post: 25-10-2006, 12:12 AM
  4. Exhast in VY II Calais
    By barbs in forum VY Holden Commodore (2002 - 2004)
    Last Post: 15-01-2006, 06:17 PM
  5. twin 2.5
    By VNV850 in forum VT - VX Holden Commodore (1997 - 2002)
    Last Post: 17-07-2005, 08:18 PM
