Results 1 to 13 of 13
Thread: engine light flickin on n off any ideas???
    evl-304's Avatar
    evl-304 is offline lovin tha v8 grunt
    vn calais v8 5.0
    May 2008
    Hobart Tasmania
    Default engine light flickin on n off any ideas???
    hey guys n girls my vn v6 is running really well but the enginelight flicks on n off while driving any ideas???
    not low oil checked that,temp is all good no miss or anything bit baffled really haha
    any help would b great
    vs calais eco
    Sep 2006
    Disney land!
    when ya find out what it is let me know as my calais does the same thing:P
    VN Wagon
    Feb 2005
    evl-304's Avatar
    vn calais v8 5.0
    May 2008
    Hobart Tasmania
    is that by bridgin the white n black wire??? i got code 12 which is all good if thats what u mean??
    VNV6VENGEANCE's Avatar
    VNV6VENGEANCE is offline VeNgeance
    VN Turbo
    Jan 2006
    adelaide,sa
    if you have a shift kit it can cause your engine light to flick on and off. The trans pressure is higher so it trips out the ecu.
    only good cops a dead cop...
    s1 vn commodore turbo
    t3/t4 front mounted turbo
    Intercooler ---3"exhaust
    stage 2 shift kit---B&M Qicksilver shifter
    3:45 lsd
    18" Cv8z Monaro rims 245's
    Cursed CX8 is offline Banned
    VY Adventra
    Feb 2008
    Walking distance to FG meets
    vnv8driver is offline Banned
    304 Calais
    Aug 2007
    Up your mum
    my guess is either a faulty oil pressure switch or o2 sensor. but you should of gotten a code logged if the light came on. did you reset the battery then test it?
    VP Commodore
    Aug 2008
    hey, i had this problem happen to me some time ago. i was told that the light comes on everynow and then if it is due for a service. i never let anyone else service my car, as it is a waste of money and i can do it myself.
    so i took it to a friend of mine who is an autoelectrician, and he tuned it off for me. not 100% sure wat he did tho. but as far as i know it has to be turned off by someone with the correct tool.
    hope this can eb of some help.
    Jul 2008
    I have the same problem on a 92 vp, id like to know the fix allso, It runs ok, drives ok etc. When your accelerating its ok, if you just coasting with a bit of throttle its ok, its only when you take your foot of the go peddal it comes on, or if your just sitting there idleing.
    VP Executive R-spec
    Jan 2005
    I haven't read a thread with more untrue rumours in it in years all you guys need to go back to engine light school asap
    304 Calais
    Aug 2007
    Up your mum
    VP Commodore
    Aug 2008
    Quote Originally Posted by greenfoam View Post
    well wat is the problem then, and how do you suppose it is fixed.
    br14nh's Avatar
    br14nh is offline Back in the saddle....
    VX V6 wagon 5sp Manual
    Aug 2007
    SW Sydney
    I had my 92 VP serviced by Lube Mobile once (and only once!) before setting off on a long trip... engine light kept coming on, turns out that a few of the sensor connectors weren't plugged back in properly.... it would be worth checking all your O2, oil pressure, knock sensors, etc. to make sure the connections are OK and wires are not worn or damaged, any splits in the wire insulation could expose the wires and cause this sort of error.
  1. Oil pressure light on after engine degrease - any ideas
    By walpoo in forum VR - VS Holden Commodore (1993 - 1997)
    Last Post: 22-12-2007, 06:30 AM
  2. 5.0ltr vr engine light on, hearing trans thump into second,any ideas
    By rossnguyen in forum VR - VS Holden Commodore (1993 - 1997)
    Last Post: 17-12-2007, 08:39 PM
  3. Shift Light In Cluster? Ideas?
    By VN_Pretz in forum Electrical Wiring / Questions
    Last Post: 17-12-2007, 07:25 PM
  4. Cruise control/ Park light problems..ideas??
    By vtcustom in forum VT - VX Holden Commodore (1997 - 2002)
    Last Post: 03-12-2006, 06:11 PM
  5. Gearbox/ engine ideas
    By Stretchomatic in forum VR - VS Holden Commodore (1993 - 1997)
    Last Post: 11-04-2006, 04:55 PM
