Results 1 to 3 of 3
Thread: Stuck! Order of main bearings???
    1989 VN Berlina
    Jul 2008
    Gladstone, Queensland
    Default Stuck! Order of main bearings???
    I have a major problem. I just bought a 89 VN berlina and decided to change the big end and main bearings. Problem is, Ive already changed the big ends and have started on the main bearings but for some stupid reason I threw out the old main bearings (which I had numbered) with the old big ends.
    The shells are numbered so Im not sure if the upper and lower shells with matching numbers are pairs??? I know the position of the number 2 bearing which controls end float but for the rest Im clueless. Would anyone know anything about this? Any help would be really appreciated.
    Rhyan
    Pub247's Avatar
    Pub247 is offline Donating Member
    92 VP wagon Daily
    Apr 2006
    Melbourne S.E.
    Have you sorted it out yet? One bearing should be larger than the others. They are paired together. They are put in order when you Put the end bearing in they will go in order from there.
    If you need more help i will get the exact order for you ok found somethign that will help you
    ACL Race Bearing Order
    1989 VN Berlina
    Jul 2008
    Yeah thanks mate. Managed to get them in, so its all good. Got the order from the ACL site you mentioned
    Cheers!
  1. conrod and main bearings
    By sebstenator in forum VN - VP Holden Commodore (1988 - 1993)
    Last Post: 26-07-2008, 10:33 PM
  2. 'best' order
    By Gaming Warrior in forum Car Audio
    Last Post: 17-04-2008, 10:24 PM
  3. Have a SV6 on order
    By yogles in forum VE Holden Commodore (2006 - ?)
    Last Post: 06-04-2007, 12:00 AM
  4. in what order?
    By r_i_d_a_h in forum VR - VS Holden Commodore (1993 - 1997)
    Last Post: 07-03-2007, 07:37 PM
  5. VS Wheel Bearings & Axle Bearings
    By Harvs82 in forum VR - VS Holden Commodore (1993 - 1997)
    Last Post: 25-09-2006, 07:41 PM
