Results 1 to 7 of 7
Thread: Starting Issue
    VN Executive
    Apr 2007
    Wellington, New Zealand
    Default Starting Issue
    when i start my car after its been sitting outside all night it runs really rough.
    it just started doing it just recently normally it would just start straight away.
    when you start it, it will crank for a bit then slowly come to life running rough until i push the accelerator and give it a bit of a rev.
    dad thinks it could be the choke, i dont know how the choke on an EFI works so i have no idea.
    anyone had a similar problem?
    cheers
    1993 Series II VP Calais
    Sep 2006
    my car had a similar problem just before it died completely =P, a new engine fixed my problem.
    EFI engines don't have a choke either, the fuel/air mix is controlled by the computer
    Morton's Avatar
    Fairstar the Funship
    May 2006
    For a start, your dad is wrong
    Sounds like either:
    a) leaky injectors causing a few cylinders to flood overnight, leading to hard starting
    but more likely:
    b) a fouled inlet manifold or head gasket, causing oil or water to enter a few cylinders overnight, meaning when you start in the morning things are a bit lumpy and far from ideal. It won't run smoothly until you rev it, because doing that is blowing the crap out.
    Get a compression test done as soon as possible, or if you're a little mechanically confident, take off your inlet manifold to check for breaks in that gasket, because it's far more likely for an inlet mani gasket to go than a head gasket. As a general rule, you have to do something seriously wrong to blow a head gasket on holden motors.
    The 1972 HQ Kingswood
    VN Executive
    Apr 2007
    i had suspected a gasket of some type and that water or something is entering the clyinders. im replacing the water pump and thermostat on the weekend, so ill take a look at it then.
    ill see if my mate can do a compression test at his shop.
    cheers
    Morton's Avatar
    May 2006
    When you next start it up cold, check for an excessive amount of white or other smoke from the exhaust. More than the usual cold startup mist. This would indicate coolant burning off Also, if things get desperate, leave your car for 24hrs, then disconnect the fuel pump fuse, unplug a spark plug and injector, and crank the engine over with some paper towel over the spark plug hole and see what comes out
    VN Executive
    Apr 2007
    im going to do my inlet gaskets this weekend with a bit of luck. i've got a haynes manual or a gregories cant remember which one. but it has detailed instructions in it.
    i also found a way to lessen the amount of water entering the chamber, by cooling the motor down (using the thermofan bypass swtich) to about 1 bar on the temp gage (OP temp is about 1 Bar) it starts better.
    before i started doing that the temp would be around 3 - 4 bar due to the hilly mission i go on to get home. heating the gaskets and making them expand.
    VN Executive
    Apr 2007
    update:
    i have noticed coolant around the inlet gasket on the left cylinder bank along with oil. does the confirm a damaged inlet manifold gasket?
LinkBacks (?)
  1. 23-07-2008, 10:50 PM
  1. Starting Issue
    By ecotec in forum VT - VX Holden Commodore (1997 - 2002)
    Last Post: 25-09-2010, 03:52 PM
  2. Odd starting issue
    By SSbeast in forum VR - VS Holden Commodore (1993 - 1997)
    Last Post: 30-11-2007, 02:21 PM
  3. VS and VT ecotec Starting issue
    By yyg998vsute in forum VR - VS Holden Commodore (1993 - 1997)
    Last Post: 15-12-2006, 11:38 PM
  4. weird starting issue
    By bradyboi in forum VR - VS Holden Commodore (1993 - 1997)
    Last Post: 11-12-2006, 08:29 PM
  5. Starting Issue
    By Glover0 in forum VR - VS Holden Commodore (1993 - 1997)
    Last Post: 18-03-2006, 10:29 AM
