Results 1 to 7 of 7
Thread: How do I remove a VP Front Bar?
    fazz1977's Avatar
    fazz1977 is offline myspace.com/fazz_himself
    1992 VP Executive Wagon, L27 V6 3800
    Aug 2005
    Frankghanistan, Melbourne, VIC
    Default How do I remove a VP Front Bar?
    Hey, I'm in the process of painting and fitting an SS kit to my VP wagon, got no issues getting the rear bar off, but the front I have no idea.
    Any pointers would be greatly appreciated.
    Life's Grouse in Frankston South!
    azkwazere is offline Ahhh Yes, Ahhh Yes....
    VP 5-SPD / 24-SPD Racer Hybrid
    May 2005
    .....SE Burbs
    Yeah its fair easy...
    There is a few ways...
    Theres the retarded way which EVERYONE will tell you to do for some reason which involves like 8 nuts or some **** to take the bar off the reo bar... **** that.
    grab a 19mm socket, slide under the car, undo the rear reo bar bolts(adjusters), undo the front reo bar bolts(fixture)... slide bar + reo off.... literally a 2 minute job.
    The reo bolts are near the sway bar mounts on the car.
    Depending on the car it may have 2 screws holding the rear of the bar to the wheel arch. (may)
    aZk.
    88GreenVN's Avatar
    88 Green VN Wagon 389,000kms
    Jun 2006
    Deep South - VN Country
    4 bolts hold it on, on the out side of the chasis rail 2 each side. Take your grill off 3 screws first. when all 4 bolts are out the bar slides forwards. Watch for the corners kicking up and scratching the mudgaurds. 5 min job.
    and 3 Dangerous non ABS VN's
    fazz1977's Avatar
    Aug 2005
    Cheers guys.
    The only reason I asked is I thought it's probably going to be easier to fit the ss lip to the bar when it's off the car, and it's fairly slammed.
    Thanks again.
    88GreenVN's Avatar
    Jun 2006
    Quote Originally Posted by fazz1977 View Post
    Cheers guys.
    Thanks again.
    Yep I'd take it off so you can work at a proper hight.
    Morton's Avatar
    Fairstar the Funship
    May 2006
    Quote Originally Posted by azkwazere View Post
    aZk.
    lol, who the **** removes the bumper from the reo! I've never ever seen that done
    God have mercy on the individual who tries that. I have enough trouble separating the two off the car, let alone on it! :P
    The 1972 HQ Kingswood
    Dumped IRS VS Acclaim 3.8, VR Stato Caprice 5.0
    Nov 2007
    Hatton Vale. country at its best. :)
    i agree with u morton!!
    why undo it from the reo????
    its easier to undo 4 bolts on the chassis and then slide the whole bar of in one!!!
    if u cant do it that way, why even try and do it yourself the long and hard way!!!
  1. How do you remove the front headrests?
    By Azkatro in forum VZ Holden Commodore (2004 - 2006)
    Last Post: 03-03-2012, 02:41 PM
  2. How do i remove vy front bumper bar?
    By hux in forum VY Holden Commodore (2002 - 2004)
    Last Post: 14-06-2009, 09:32 PM
  3. Remove stering wheel front.
    By ozzie_online88 in forum VY Holden Commodore (2002 - 2004)
    Last Post: 21-07-2008, 09:46 PM
  4. how do you remove the headrests from the vl front seats??
    By lil_oneblue in forum VL Holden Commodore (1986 - 1988)
    Last Post: 19-01-2007, 08:28 PM
  5. How to remove front CV driveshafts ? ...
    By Hairy Eater in forum The Pub
    Last Post: 27-08-2006, 10:06 PM
