Results 1 to 5 of 5
Thread: - Help** - a/c belt throws off other belts VN
    '91 VN SS
    Aug 2005
    Default - Help** - a/c belt throws off other belts VN
    Hi all,
    as the heading states - when i have an a/c belt fitted to the car (5l v8) it either squeaks really loud and snaps (only happenned once), or it throws the belt off, which then throws the other two belts off.
    any solutions??
    Cheers,
    Jazack
    accentstencil's Avatar
    WH II Caprice, 5.7
    Jun 2005
    Eschol Park, Sydney
    When you turn the A/C pulley by hand, is it hard to turn or is there excessive play? Does it happen regardless of whether the A/C is turned on or off?
    MY RIDE
    Reaper's Avatar
    Reaper is offline Tells it like it is.
    E3 Senator Manual, VP SS
    Aug 2004
    First step is to check the tension (most likely) and then that the pulleys are in line. Also check that your aircon compressor isn't seized.
    Reaper
    Reapers Black VP SS
    0-60 mph = 5.39 Sec, 2.30 60'
    Quote Originally Posted by skruba View Post
    practice makes perfect dude i was (still am) my bros guinea pig,he has been tattooing for near 2 years.
    '91 VN SS
    Aug 2005
    Reaper
    how do I check if they are inline, is this just a visual inspection - if so, they appear to be ok. compressor was reconditioned so there should be no problem there.
    Quote Originally Posted by accentstencil View Post
    the a/c pulley is easy to turn by hand, and the issue only occurs when the ac is turned on.
    Jul 2008
    If its standard you'd assume the pulleys line up, if your certain the problem only occurs when ac is on, perhaps when the ac clutch engages something jamming/seizing up?
    Are you replacing the belt yourself? it shouldn't be loose nor overly tight.
  1. belts slipping
    By dijm8 in forum LSx Development and Modification
    Last Post: 07-10-2011, 12:03 AM
  2. vs engine belts
    By alan smithy in forum VR - VS Holden Commodore (1993 - 1997)
    Last Post: 06-08-2008, 11:47 PM
  3. serpentine belts on v8
    By LindasBT1 in forum VN - VP Holden Commodore (1988 - 1993)
    Last Post: 04-07-2006, 12:03 AM
  4. Seat Belts
    By jamiekratin in forum VB - VK Holden Commodore (1978 - 1985)
    Last Post: 13-09-2005, 11:00 PM
  5. Noisy belts on V8
    By Tony2 in forum VR - VS Holden Commodore (1993 - 1997)
    Last Post: 07-10-2004, 11:44 PM
