Results 1 to 20 of 20
Thread: VP Ticking
    Jul 2008
    Default VP Ticking
    I was wondering If Vp's suffer the same timing belt issues Vn's do ?
    I Have 92 vp manual, and the dam thing ticks.........
    Its a constant tick that sounds asiff it progreses into a rattle, it follows the rpm ( goes faster when you mash the pedal on the right )
    Sometimes its pretty loud others its not, If you roll down your window you can definatly hear it.
    The cars pretty bog stock, apart from a set of extracters, zaust and lpg kit,
    I get the occasional LPG backfire but thats a different issue.
    Any suggestions its driveing me NUTS......
    The car only has 185 000 on the clock
    Pub247's Avatar
    Pub247 is offline Donating Member
    92 VP wagon Daily
    Apr 2006
    Melbourne S.E.
    could be injectors especially if its on gas they might be block. Use the old ear to end of a screwdriver trick and see if it coming from injectors
    georgeonboost's Avatar
    georgeonboost is offline clutch it!
    slammed VP EXEC
    Jun 2005
    Melb SE Suburbs
    i have this problem too and my car is on gas which just started happening 2 days ago. my mechanic told me it was the injectors. would putting injector cleaner through it fix it?
    -George
    Jul 2008
    If its a subtle ticking then thats normal, just injectors working. if its a metallic or rattling type of sound, may be bearings in the front pulleys, timing chain , hydraulic lifters/dirty oil, transmission, etc.
    Jul 2008
    The Injectors dont fire while the car is running on gas, ITs a manual, does it with the clutch in, in droping the oil tomorrow, a lifter i can deal with, a timeing chain that can be replaced, but if its something more sisnister, im affraid i may haft to burn it.
    Sory guys, im at my whitts end with this car.
    Jul 2008
    sorry should of read it was manual and your running on straight gas, most likely the timing chain or lifters, they can make the sound you described and sound worse than what it really is.
    '92 HSV VP GTS
    Apr 2005
    SE Queensland
    Take a rocker rover off and inspect for any loose rockers or anything out of the ordinary. Run an oil flush through the car and then change the oil to a 20w50 or something of the likes, your oil may be too think atm and your lifters may be sticking also.
    Pub247's Avatar
    92 VP wagon Daily
    Apr 2006
    Melbourne S.E.
    timing chain or lifters aren't too hard fix chain is a pain in the car but doable. What i hate about the internet is trying to diagnose noises when you cant physically hear them.
    Another one could be an exhaust leak. Does it do all the time or only when the clutch is is in? If so more likely chain
    Steery's Avatar
    Steery is offline AA 554 G
    94 VR SS M5
    Feb 2008
    Adelaide, near Cross Road Maccas.
    my car has a rattle that progresses through the rpm, sounds like a metallic sort of rattling noise.
    what my mechanic told me is that when the serpentine belt gets dirt and muck in it (because it has grooves that run the length of the belt) it makes the metallic rattling noise which can easily be mistaken for a timing chain. if you have cracks etc in the belt then chances are its dirty as **** and replacing it could quite possibly get rid of the noise.
    they are loud ****ers.
    Jul 2008
    I would still say a bearings gone or lifters if its a mettalic rattly sound, ive never heard of that before steery.
    BUT50 is offline BUT50
    VX Executive S2-VN SS
    Mar 2007
    Sounds like a sticking lifter to me gve it a good flush out with wynns engine flush or the like and use some thicker oil something like engine armour
    Jul 2008
    Thanks guys, i will give it a go, I sused it a bit more today and its definatly comeing from the rear right close to the firewall.
    Jul 2008
    Upon further listening, definatly right rear, If you get under the car it gets louder. Tightened all exchaust bolts checked for leaks, did flush, droped oil, no difference apart from sometimes, it goes very faint.
    Troy5L's Avatar
    Troy5L is offline building a lemon
    Blown VS Clubsport, Hektic Bravo ute
    Jun 2005
    Mornington peninsula
    i had the same problem 2 years ago, its the lifters, they are farkd. get a new pair, or take it to a mechanic, apparently they are platic ones, but the ones in the ecotech are metal and last longer, well thats what my mechanic said, so now i got ecotech, and it cost me d1ck all for him 2do
    Vortech V1 supercharger : 10psi : Intercooled : 3.89 Mini-spool : VT Big Brake conversion : Shift kitted auto : B&M Shifter
    My VS CLUBBY!
    237.2RWKW - 318.1HP - 926.4 NM
    Quote Originally Posted by ari666 View Post
    "putting additives in your oil is like putting things up your bum.... to some people its the best thing in the world, but to me its the most horrid thing i coud possibly imagine"
  15. #15
    Jul 2008
  16. #16
    Pub247's Avatar
    92 VP wagon Daily
    Apr 2006
    Melbourne S.E.
    Quote Originally Posted by VRSLT323 View Post
    Lifters arent plastic they are all metal and yes ecotec are exactly the same.
  17. #17
    Jul 2008
    Since the oil change you can barely hear it on idle now, but once you get up to 2g its a clear as a bell.
    A totaly unrelated question, does anyone elses heater suck arse ? If so how can i fix it ?
  18. #18
    Pub247's Avatar
    92 VP wagon Daily
    Apr 2006
    Melbourne S.E.
    my heater worked fine you could check the actuator rod which is down on the right hand side of the center console in the driver's footwell sometimes the plastic clip is broken and they either moved or havent been set correctly not allowing the heater flap to open fully.
    Oil changes lends some credibility to lifters making the noise. Another i was thinking is the rear balance shaft bearing is a common problem but let's not hope its that
  19. #19
    Jul 2008
    I have discoverd that the car doesnt apear to have a rev limiter, Im thinking that the previus owner may have over reved it a bit. It will happly climb to 6g and make a terrible noise.
    I have checked the actuator rod, Thats the first thing i did when the heater did not work, i also checked to vacume controled heater valve thingy under the bonnet, both apear fine, i have the heater somewhat working, its just enuff to keep ya from freezing at night. I even tried tieing the vacume valve open, it didnt make much difference.
  20. #20
    Jul 2008
    I tryd to video the sound, you can just hear it, seems to be to much noise for the phone to take in,
    <object width="425" height="350"> <param name="movie" value="http://www.youtube.com/v/j-euED22MF4"> </param> <embed src="http://www.youtube.com/v/j-euED22MF4" type="application/x-shockwave-flash" width="425" height="350"> </embed> </object>
    or
    YouTube - VP.........
  1. alloytec ticking
    By f1tzy in forum VZ Holden Commodore (2004 - 2006)
    Last Post: 06-01-2008, 01:38 PM
  2. still ticking
    By mortivivosdocent in forum VT - VX Holden Commodore (1997 - 2002)
    Last Post: 07-08-2006, 03:28 PM
  3. 95 vr ticking
    By brohawk in forum VR - VS Holden Commodore (1993 - 1997)
    Last Post: 23-07-2006, 09:11 PM
  4. ticking VP
    By chevy_big_block_bro in forum VN - VP Holden Commodore (1988 - 1993)
    Last Post: 21-03-2005, 02:44 PM
  5. ticking
    By vpdood in forum VN - VP Holden Commodore (1988 - 1993)
    Last Post: 28-10-2004, 01:36 AM
