motor and boxs are different,
suspension is same front to back, just the vn diff is wider than the vl diff...
seats does fit with a bit of trouble, and exhaust are different also, but can modify to fit ...
hope that helps u out bro...
The entire engine, driveline and suspension will bolt in. Diff will fit with the right wheels, Pretty much everything important goes straight in (if you want a V6 VL)
keep your vl diff in there or lying around as it helps if you want to put wide tyres on later down the track.
only good cops a dead cop...
s1 vn commodore turbo
t3/t4 front mounted turbo
Intercooler ---3"exhaust
stage 2 shift kit---B&M Qicksilver shifter
3:45 lsd
18" Cv8z Monaro rims 245's
