Hey all got a VP last week ran cold as but had lots of gunk in radiator and H20 in it. Removed radiator, Reverse flushed it & Put new thermostat in and coolant. Now it runs hottish (just under half) pretty much all the time. What can i do??? How do i bleed it? and what temp should a VP with coolant and new thermostat run at??? HELP!!! Cheers
mine runs around a quarter on normal temp. depends on the weather and how u drive it
2 bleed it i leave the cap off while its running and let the air bubble out while toppin it bak up.
Cheers guys i'll let ya know how i go on saturdy
when i changed me thermostate it ran hotter...around teh mark that you say. however i would still make sure there is no air in teh system for good measures
