Results 1 to 14 of 14
Thread: how to change timing chain
    VP Executive S2
    Oct 2006
    Default how to change timing chain
    hey guys,
    could someone give me a step by on how to change the timing chain on my VP
    thanks
    Pub247's Avatar
    Pub247 is offline Donating Member
    92 VP wagon Daily
    Apr 2006
    Melbourne S.E.
    Timing chain is a bit difficult to do in a car due to the bottom of the timing cover is bolted to the sump.
    Things you'll need is timing cover gasket, New timing chain kit(better than buying just a chain) new tensioner. Possibly a few other gaskets depending on what you remove. I suggest doing your water pump while your at it.
    The Crow heavy Duty timing set CS6VP (rrp $175) is good Might get it cheaper if youre lucky.
    The Basic plan is
    Drain cooling system,
    Remove harmonic balancer (PITA need puller and usually a rattle gun to remove retaining nut)
    Remove Water pump(actually can remain on timing cover just undo the bolts that go through the pump and cover to the block) and anything else in the way of removing timing cover.
    Remove timing Cover
    Rotate Engine to TDC (easier with spark plugs removed) Both dots on sprockets line up with another (cam dot at bottom crank dot at top)
    Remove tensioner (if it's still there ) chain and timing gear/sprocket from camshaft.
    Check that the balance shaft timing mark line up with cam gear.
    Replace sprocket/s
    Use straight edge to make sure both sprockets are aligned
    Fit new timing chain and tensioner ( note on tensioner there's 2 types short bolt and long bolt late model vr-to vx run long bolt some late vp's may also use long bolt. Check by examining hole threads starts deeper in on long bolt tensioners)
    Check that timing chain does not foul on timing cover or balance gear
    Re-assemble everthing Paying attention to make sure your gasket surfaces are clean i suggest using an aviation sealant like loctite No.3
    Thats the basics if you got some mechanical skills you should breeze through it. If you dont want to remove sump i suggest using silicone or sikaflex type seleant around the sump so it doesnt leak.
    Cheers Pub
    PS I Reported that this thread should be moved instead of bitching about people posting in the wrong section
    Last edited by Pub247; 26-09-2008 at 05:38 PM. Reason: Add more information about tensioner
    VP Executive S2
    Oct 2006
    thanks heaps, was my first post so wasnt 100% sure were to put it.
    Thanks again
    VrWagz1's Avatar
    Vr S2 exec 5.0 man Wagon
    May 2008
    wollongong
    When should you change your timing chain. On rough you do a timing belt every 100k. But how many k's for a timing chain.
    Reaper
    VP Executive S2
    Oct 2006
    easy decision for me, mines making a hell of a noise, think i read somewhere to expect to change it after around 150 000 km
    Pub247's Avatar
    92 VP wagon Daily
    Apr 2006
    Melbourne S.E.
    GTP 85's Avatar
    GTP 85 is offline 291 hp @ the wheels
    VS track car & VS SSenator
    Aug 2006
    Adelaide, near the bay
    replaced my chain and gears recently with a rollmaster kit, beautiful piece of workmanship! lol
    my engine only has 140 000km, well maintained, and the stock chain was loose as fk! you could twist it pretty far, where as the rollmaster chain was rigid as.
    Hit me up with some reputation points if i've helped you out! (Star in the bottom left!) Cheers!
    GT Performance RUF 231- NA 3.8L- 13.30 @ 103 Mph... So far... Cam, compression and revs! MY CAR>> http://forums.justcommodores.com.au/...tml#post471410
    Daily VR SS: http://forums.justcommodores.com.au/...ite-vr-ss.html
    VrWagz1's Avatar
    May 2008
    wollongong
    Weird, iv got nearly 190k on my vr and no timing chain noise what so ever.
    Reaper
    VN Executive
    Apr 2007
    Wellington, New Zealand
    GTP 85's Avatar
    Aug 2006
    Quote Originally Posted by VrWagz1 View Post
    Its not only noise that identifies a shagged chain! mine didnt make any noise!
    you would barely notice the performance depreciation, cause over time the timing slowly slips out of wack.. and the power slowly falls away over the years.
    You actually would never no unless you opened the timing case up to have a look.
    Not trying to pannic anyone into changing theirs now... Just throwing out another "could be??" for anyone who notices bad performance
    missus (in more ways than one)
    Sep 2005
    get a gasket kit cause your gasket will be nice and backed on, best way to egt it off (unless it peels off) is to take a flat head screwdriver, and just tap it lightly, gasket will crack off bit-by-bit
    also if you mark the block sand it back smooth
    selling victorian number plates MADVN6,
    pm me if interested
    88 VN 5spd 3.8
    Apr 2007
    Corio,Victoria (Geehole)
    Remove tensioner (if it still there )
    after removing my sump today i found my tensioner spring sitting inside
    1989 VN Berlina
    Jul 2008
    Gladstone, Queensland
    Quote Originally Posted by the executive View Post
    I had the same issue with my VN when changing the timing chain. Found the tensioner smashed up in the sump with the metal spring. Quite shocking to find considering the damage it could have done to the engine. I think the issue with how long a timing chain lasts may have to do with how long your tensioner decides to stay put
    vp 5L
    Jul 2008
    goldcoast
    im looking at doing my timing chain in my vp v8 and i found a rollmaster double row timing chain kits for $150 to my door , i just wanted to know if i need to advance the sprocket a few degrees to alow for timing chain streatch ,if so how many
  1. HSV double-row timing chain vs timing gears
    By savage1987 in forum V8 Development and Modification
    Last Post: 05-10-2007, 12:04 AM
  2. timing chain
    By timboco in forum VR - VS Holden Commodore (1993 - 1997)
    Last Post: 10-06-2006, 06:09 PM
  3. timing chain
    By howareyou in forum VN - VP Holden Commodore (1988 - 1993)
    Last Post: 17-09-2005, 05:49 PM
  4. vn timing chain
    By kacriss in forum VN - VP Holden Commodore (1988 - 1993)
    Last Post: 12-08-2005, 07:02 PM
  5. VN Timing Chain
    By Michal in forum VN - VP Holden Commodore (1988 - 1993)
    Last Post: 08-09-2004, 08:39 AM
